guns_usn_20 Posted January 22, 2025 #1 Posted January 22, 2025 Years ago I think there was a harness for the h e Stebel air horn that kept the high current from the horn passing through the horn switch. Does anyone have a link to the discussion on here. I would like to get the installation instructions if possible. Thank You Jim Bell
RDawson Posted January 22, 2025 #2 Posted January 22, 2025 2 hours ago, guns_usn_20 said: Years ago I think there was a harness for the h e Stebel air horn that kept the high current from the horn passing through the horn switch. Does anyone have a link to the discussion on here. I would like to get the installation instructions if possible. Thank You Jim Bell You might check with @M61A1MECH. He builds quality plug and play light harnesses but I’m not sure about horn sets. The main goal is to run a fused hot wire from the battery through a relay to power the horn. I built my own and used the factory wires to fire the relay.
vzuden Posted January 22, 2025 #3 Posted January 22, 2025 CarbonOne used to make brackets and harness but I don’t believe he is active any longer. You can search on his name and maybe find something
vzuden Posted January 22, 2025 #4 Posted January 22, 2025 Search under Horn Bracket and you will see several entries on this
M61A1MECH Posted January 23, 2025 #5 Posted January 23, 2025 Sorry but the Stebel harness was not one of my products. It should be a very simple harness. Connect the OEM plug to a relay to energize the coil and run a fused line from the battery to one side the Normally Open (NO) contact of the relay and connect the input for the Stebel to the other side of the NO contact. Push the horn button and the relay closes making the horn blow. The tricky bit is making sure the relay is rated for the current needed for the Stebel horn, size the wire and fuse accordingly for the current needed by the horn. I could build one, but not having a Venture around to determine what connector is needed or estimate the length or wire needed, I would need some help in the form of pictures of the horn connector, and estimate of length of wire needed to get from the battery to the new horn. 2
