FutureVentures Posted June 5, 2008 Posted June 5, 2008 So, the radio has been intermittent, at best last few weeks. Comes on, goes off, all on it's own. Tried the recommendation tonight of, splitting the fairing, reseating the big connectors and applying di-lectric grease before the last reseat. All, to no avail. Here's the current symptoms. -Radio plays through rear speakers only. -Volume control does nothing, doesn't get louder even at 30, only goes mute when it goes to zero. -When adjusting volume, the front speakers make that beep with every volume click, so they're working. -Also, the CB transmits through all 4 speakers and the volume adjustment for that, works fine. -Aux still doesn't work. Thought I was on to something when I discovered the connector from amp to cassette wasn't connected together. Still didn't work though, after connecting. One dealer thought it was the "head unit" needs to be replaced. Is that the amp? Another dealer thought, it's the antenna... So, it's sitting in the garage looking ugly, as the fairing is off. Luckily, rain tomorrow.....I hope. Any idears? Perty please?
BuddyRich Posted June 5, 2008 Posted June 5, 2008 You did do the one with the Blue band on it ? Could be the Control Unit. That's the one on the handlebars.
BuddyRich Posted June 5, 2008 Posted June 5, 2008 Since your outta warranty you could try taking the Control apart and blow it out. Maybe that will help. I took mine apart once.
FutureVentures Posted June 5, 2008 Author Posted June 5, 2008 Did take the blue one apart, all of em. Agree about control unit, worth a shot. Dang it all. Thanks!
Jerry W Posted June 5, 2008 Posted June 5, 2008 When my radio was acting up, I cleaned, greased and reseated all the connections, not just the big ones. I don't know which one was the culprit, but it works great now. You might try cleaning and greasing the rest of the connections since the faring is already split. Just a thought
Midrsv Posted June 5, 2008 Posted June 5, 2008 It's been a while since I looked at mine, but I think there is a balance adjustment from front to rear. Could it be that is biased to the rear? Just checking the simple things first. DT
GigaWhiskey Posted June 5, 2008 Posted June 5, 2008 Head unit (cassette player, ha), dunno. That mute/channel changer, when it has water in it, can make a mess of things (is it cranky muted, dunno). Can that be uplugged and then try it, I dunno. Rear speakers? Not stock (this is a first gen right?). Make sure you got the noise sensor part of the volume turned up. You say comes on goes off, is that power? I dunno, just tossing things out there.
FutureVentures Posted June 5, 2008 Author Posted June 5, 2008 When my radio was acting up, I cleaned, greased and reseated all the connections, not just the big ones. I don't know which one was the culprit, but it works great now. You might try cleaning and greasing the rest of the connections since the fairing is already split. Just a thought Might as well try it, the fairing's still off. I'll give that a shot tonight when I get home. For the other's feedback; Yup, checked the fade, doesn't do anything any more. It's a 2000 MM, 2nd generation. Thoughts I was on to something when I found the Aux cable from Amp to Cassette wasn't even connected but, no luck. I'll grease it all up tonight and see what happens. Maybe I'll find a cassette (we still have some) and see if that's working or not. One more piece of the puzzle.... Thanks again.
GeorgeS Posted June 5, 2008 Posted June 5, 2008 OK, Idea, you may have allready done this, however --- In that you still have all the fairings off. With the System, working in the Defective state, go over all the connectors carefully, one at a time, and move or wiggle them carefully. Try not to disturbe more then one connector at a time. IF-- the problem is a plug or connector, you might be able to pin point it this way. IF, the problem was the Antenna system, Then the AM would be much more effected then the FM.
FutureVentures Posted June 6, 2008 Author Posted June 6, 2008 I dunno what's the deal, I tried everything under the sun, per recommendations here. Nothing helps. Plus, now I can't get the middle screw on the left and right side on the back of the fairing back in, threads don't catch. Grrr.... Advice on that? But anyway. I can hear through all 4 speakers, barely, with no volume control, with MCU detached. Noticed when I unplugged/plugged the blue MCU cable in the fairing, it would make a pop noise and sound would return to the front speakers. Checked all fuses, are all good. Greased all connections, twice. Took apart the MCU, to the point I discovered it's water tight, then put back together. Doh. I'm starting to think it is indeed, the Clarion head unit. Bummer, cause that's expensive. Anyone have one to sell, cheap? Or know where to get one? Nothing like spending two hours dinking around, to no avail....... But hey, I did learn more about the guts of the fairing. Idears? Cause, I give up.
r12guy Posted June 7, 2008 Posted June 7, 2008 I was having a simular problem with mine. But mine would come and go as it pleased. it took a few trips to the shop before they took my word for what it was doing. What i came up with was the control head on the handle bars. Mine was replaced and its has been fine ever since.
JoeFab Posted June 7, 2008 Posted June 7, 2008 Does anybody on this thread happen to have an extra volume control knob laying around? Man I need one... Thanks. Joe
gunboat Posted June 7, 2008 Posted June 7, 2008 hi rv just went thru all the parts listed by pinwall cycles, no mcu listed. i called them once about a part not listed. was told if it's not listed it's no good. i think your right about the mcu, but i will still send the radio to ya to try. if it fixes the problem then we have a deal if not just ship it back. i hate electrical problems. best reguards don c.
