captdrac Posted June 27, 2023 Posted June 27, 2023 Hey fellas, HELP!!! A ugly situation reared its head for me! I changed my tires and checked my brakes for wear and the pads were still good at 35K miles. The only thing I did was to separate the front right caliper piston by hand a little to put it on the rotor. When I took it for a test ride, the front brake lever pulled to the grip and I had no front brakes! After 1-2 pumps of the lever, I had full braking power. It happened almost every time I used the lever. The rear brakes are fine thank God. After returning home, I bled the front brakes. I took the Venture out again, and still the same problem. Any suggestions on what anyone thinks may be the problem? I'm thinking about buying a rebuild kit for each front caliper and rebuilding them. Can anyone suggest a inexpensive, reliable parts store for my Venture besides the dealership that, from what I can see, only has individual parts and cost $$$ for the few pieces I need for the rebuild.
RDawson Posted June 28, 2023 Posted June 28, 2023 Try bleeding the master by cracking the banjo bolt. If an air bubble gets up there it’ll drive you crazy. 1
captdrac Posted June 29, 2023 Author Posted June 29, 2023 I'll try it today & give an update. Thanks!
captdrac Posted July 12, 2023 Author Posted July 12, 2023 Well, I've tried tapping on the bajo bolts / joints while bleeding the system. still the same problem. I ordered a front master cylinder and hope that the replacement does the job. Since I've had the cycle, I would sometimes get a code 51. According to the service manual, it indicates that the ABS is getting too high of a voltage from the electrical system. If this doesn't work, to the shop it goes. My problem with that is the tech I trusted at the shop to go to was hospitalized and now isn't returning. Any suggestions on what shop I could trust for us living in SE Wisconsin?
