Piegus79 Posted December 27, 2022 Posted December 27, 2022 How to check if the class screen works. Where to connect + & -
Marcarl Posted December 28, 2022 Posted December 28, 2022 First off, make sure it's plugging in properly, then turn key to acc mode, screen should light up. If not you most likely have a cold solder joint that needs to be resoldered.
Piegus79 Posted December 30, 2022 Author Posted December 30, 2022 You were right. Already done . Thank you very much for your help
Stream Rider Posted June 30, 2023 Posted June 30, 2023 Would you be able to share a link to a previous post or information on what needs to be soldered? I would appreciate it greatly. I have a full manual and can solder but not sure what i am looking at on the back of the boards.
luvmy40 Posted June 30, 2023 Posted June 30, 2023 3 hours ago, Stream Rider said: Would you be able to share a link to a previous post or information on what needs to be soldered? I would appreciate it greatly. I have a full manual and can solder but not sure what i am looking at on the back of the boards. Here's a link to the Venturers forum that goes over the repair. https://venturers.org/Tech_Library/index.php?action=article&cat_id=001007&id=317 1
Stream Rider Posted July 1, 2023 Posted July 1, 2023 9 hours ago, luvmy40 said: Here's a link to the Venturers forum that goes over the repair. https://venturers.org/Tech_Library/index.php?action=article&cat_id=001007&id=317 Thank you SO much!
