Igpig Posted September 21, 2020 Posted September 21, 2020 Hey guys, hope someone can help me with this. I just put new 5 pin plugs on a set of 7 pin headsets, and it all works except intercom. when i turn up the i/c i can hear a kind of static but no mic action. when i turn on the cb i can hear a faint pop when i push the ptt. nothing from the mic though.i have tried reversing the positive and negative mic wires, nothing. can't find a good diagram on the intercom. have a good diagram for the headset.
etcswjoe Posted September 22, 2020 Posted September 22, 2020 Hey guys, hope someone can help me with this. I just put new 5 pin plugs on a set of 7 pin headsets, and it all works except intercom. when i turn up the i/c i can hear a kind of static but no mic action. when i turn on the cb i can hear a faint pop when i push the ptt. nothing from the mic though.i have tried reversing the positive and negative mic wires, nothing. can't find a good diagram on the intercom. have a good diagram for the headset. I don't think it will work because you have no preamp voltage for the 7 pin mic form a 5 pin setup.
Marcarl Posted September 22, 2020 Posted September 22, 2020 Check out, https://jmcorp.com. They did make a lower cord for that applications I think. You may have to call them to ask.
Igpig Posted September 22, 2020 Author Posted September 22, 2020 Thank you! is there a way i can install an amplifier? I did check voltage to the mike and thought it was too low, but I wasn't sure how much i was looking for. I think it was in milivolts.
etcswjoe Posted September 22, 2020 Posted September 22, 2020 Thank you! is there a way i can install an amplifier? I did check voltage to the mike and thought it was too low, but I wasn't sure how much i was looking for. I think it was in milivolts. I tried it but could not get the right combination, however I did not spend that much time on it.
Igpig Posted September 23, 2020 Author Posted September 23, 2020 Thank you much, I'm sure a solution will come to me.
etcswjoe Posted September 27, 2020 Posted September 27, 2020 Stephen, hope have been able to find a solution. Can you just switch out the boom or the mic element? I did notice your location and although it is a year off I thought I would let you know we have a ride every other year at Vogel State Park just north of you every other year and the next one will be 11-15 August 2021 if you might be interested. Here is the link to the current discussion about it https://www.venturerider.org/forum/showthread.php?146872-Vogel-2021
