dalesocha Posted July 22, 2020 #1 Posted July 22, 2020 Ive had my 2009 RSV for almost 5 years and have not replaced the spark plugs yet. We have not ridden her in about a year. But its time to do some needed maintenance on our baby "RED". I have looked on you tube for videos nothing there? The rear cylinders are no problem, it just takes time. The front plugs look like major surgery, what can you explain or make a video to help me and others out there. I appreciate your help. I plan on making a video and posting on youtube Thanks DaleSocha
BratmanXj Posted July 22, 2020 #2 Posted July 22, 2020 While you're in there 90% of the way to get to the spark plugs you might as well do a valve check. https://www.venturerider.org/forum/showthread.php?38340-2nd-Gen-Valve-Adjustment
Guest divey Posted July 22, 2020 #3 Posted July 22, 2020 dalesocha said: Ive had my 2009 RSV for almost 5 years and have not replaced the spark plugs yet. We have not ridden her in about a year. But its time to do some needed maintenance on our baby "RED". I have looked on you tube for videos nothing there? The rear cylinders are no problem, it just takes time. The front plugs look like major surgery, what can you explain or make a video to help me and others out there. I appreciate your help. I plan on making a video and posting on youtube Thanks DaleSocha Some say that you can change the front plugs without removing the tank. I suppose it’s possible but removing the tank and then the two dog bones (supports) makes getting to the two front plugs a piece of cake. You’ll need a thin wall spark plug socket but hopefully you have the original that came with the tool kit.
vzuden Posted July 22, 2020 #4 Posted July 22, 2020 I replace mine without removing the tank. Just take the front mounts off and you can get to them. Taking the tank off is only 5 minutes and it does make it easier but is not necessary.
dalesocha Posted July 24, 2020 Author #5 Posted July 24, 2020 dalesocha said: Ive had my 2009 RSV for almost 5 years and have not replaced the spark plugs yet. We have not ridden her in about a year. But its time to do some needed maintenance on our baby "RED". I have looked on you tube for videos nothing there? The rear cylinders are no problem, it just takes time. The front plugs look like major surgery, what can you explain or make a video to help me and others out there. I appreciate your help. I plan on making a video and posting on youtube Thanks DaleSocha Got it done with the help of Technical library here on venture rider. Thanks for the person who actually took the time to do it.
videoarizona Posted July 24, 2020 #6 Posted July 24, 2020 Actually simply remove the dogbones on either side and use the toolkit (hopefully you have one). The tools make it easier to get the plugs out. You can also use a small hose, putting the plug on the end, to put the plugs back in. I used the tool kit and found it to be simple. Just remember to blow high pressure air around and down into the plug area BEFORE you take the plugs out. Will keep any nasties that have been living down in there from going into the motor.
