JR333 Posted May 13, 2020 #1 Posted May 13, 2020 I need a rear tire already at 11000km I'll be lucky to get another 2000km while risking my neck on a blowout. I've absolutely had it with over priced bike tires especially for this bike at probably 400.00 installed to go almost no where for the money spent. I think I want the Dunlop Run Flat but is it the 205/55R/16, 55 or 60 series? The speedometer is faster so correction is welcome. Anybody want to share experience using a car tire on this bike? I know the goldwing guys use car tires but I dont have a wing Thanks in advance JR
dragonstorm Posted May 13, 2020 #2 Posted May 13, 2020 Someone dicussed the dark side option here . . . https://www.venturerider.org/forum/showthread.php?137939-Darksiding-18-Venture-Eluder&highlight=tires
RonK Posted May 14, 2020 #3 Posted May 14, 2020 -- The GoldWing takes the exact same tires as the Eluder/Venture, so any info there is good here. I use the Bridgestone Driveguard Run Flat in a 205/55-16 and have 18,000 miles on it. It should go to about 26,000 with the amount of tread on it. It puts my speedometer exactly right on based on my gps. Would use it again. Fits fine without any mods other than with the tow bar from Rivco that needed some shaving of bracket in one corner. --
JR333 Posted May 14, 2020 Author #4 Posted May 14, 2020 dragonstorm said: Someone dicussed the dark side option here . . . https://www.venturerider.org/forum/showthread.php?137939-Darksiding-18-Venture-Eluder&highlight=tires Thanks for pointing out the link. I read all that the other day but the next reply after yours here is what I was looking for....experience. Thank you !!
JR333 Posted May 14, 2020 Author #5 Posted May 14, 2020 RonK said: -- The GoldWing takes the exact same tires as the Eluder/Venture, so any info there is good here. I use the Bridgestone Driveguard Run Flat in a 205/55-16 and have 18,000 miles on it. It should go to about 26,000 with the amount of tread on it. It puts my speedometer exactly right on based on my gps. Would use it again. Fits fine without any mods other than with the tow bar from Rivco that needed some shaving of bracket in one corner. -- This is the ticket (experience) I was looking for... as a first timer I'm a little uncertain of the confidence at higher speed and corners but if you have that many miles on this new model bike then I'll give it a shot. If a guy thinks for less than 2 seconds about the death wobble I think it's pretty plain to see that if you put a 7 or 8 inch tire on a 3.5 or 4 inch rim something bad is going to happen. These bikes have a 5 inch rim so I won't expect worse handling than a back bike tire wore flat down the middle. Thanks JR
djwasy61 Posted May 31, 2020 #6 Posted May 31, 2020 i been running a car tire on my victory cross country. rode the dragon about 3 weeks ago with it. handles great.
