chollahan Posted May 16, 2008 Posted May 16, 2008 (edited) Never mind, I should have done a search for the subject first. Problem solved. Edited May 16, 2008 by chollahan
chollahan Posted May 16, 2008 Author Posted May 16, 2008 I had the problem of not getting pressure on the clutch and posted in frustration. Went back out and remembered that another guy had the same problem. Did a search and found that I needed to let the mightivac suck more fluid through and went back out to the garage. Sure enough, it worked!
Squidley Posted May 16, 2008 Posted May 16, 2008 Cool...glad to hear that you got it like you wanted. I just went over to TJ's house and we bled his clutch as he was having problems. 30 minutes later it was in great shape
