RollinWoody Posted September 12, 2019 Posted September 12, 2019 I purchased the led passing lamps to replace original sealed beams for my bike but unfortunately it seems there is an issue with the "bezel " or size of the bucket not sure if i need to replace with "STR-4NK35-10-00" ? Are they the same bucket or am I missing something?? I can squeeze it in but without the rubber surround gasket that is attached.... Thanks
Sylvester Posted September 13, 2019 Posted September 13, 2019 I have an 02 RSMV and have led pass lights on it and experienced no problems. Don't know how to direct you, sorry.
slowrollwv Posted September 13, 2019 Posted September 13, 2019 I purchased the led passing lamps to replace original sealed beams for my bike but unfortunately it seems there is an issue with the "bezel " or size of the bucket not sure if i need to replace with "STR-4NK35-10-00" ? Are they the same bucket or am I missing something?? I can squeeze it in but without the rubber surround gasket that is attached.... Thanks One question. What Yamaha housings do you have? They made two driving light housings. One for the RSV and the other for the rest of the field. The RSV housing has the horizonal bolt and the others have a vertical bolt. I have the bezel with horizonal bolt on mine. The LED light sets in the bucket and the foam spacer in the bezel to hold everything tight. If you have the bezel with the vertical bolt you will have problems getting things lined up.
RollinWoody Posted September 14, 2019 Author Posted September 14, 2019 I also have the bucket with the horizontal bolt but the rubber gasket around the Led lamp would not even fit with the ring.Had to cut a little rubber tab to take it loose and now can fit however this doesn't seem right I shouldn't have to do this. Is the H3 housing larger? My housing is the 4xy-35 ........ Thanks
RollinWoody Posted September 15, 2019 Author Posted September 15, 2019 I have an 02 RSMV and have led pass lights on it and experienced no problems. Don't know how to direct you, sorry. Your passing lamps were they added by you or original accessory at the time ? I am trying to figure if the lamp buckets may have changed sizes..
RollinWoody Posted September 15, 2019 Author Posted September 15, 2019 Your passing lamps were they added by you or original accessory at the time ? I am trying to figure if the lamp buckets may have changed sizes.. Note: also did your retrofit kit Led's lamps have rubber gasket attached?
Sylvester Posted September 15, 2019 Posted September 15, 2019 Your passing lamps were they added by you or original accessory at the time ? I am trying to figure if the lamp buckets may have changed sizes.. Mine were original accessory. At least they came with the bike when I bought it new.
RollinWoody Posted September 15, 2019 Author Posted September 15, 2019 Mine were original accessory. At least they came with the bike when I bought it new. My retrofit kit kit lamps won’t physically fit the rubber gasket and my paperwork states:”(P/N STR-4NK35-10 or STR-4WM35-10EA) required....
Sylvester Posted September 15, 2019 Posted September 15, 2019 My retrofit kit kit lamps won’t physically fit the rubber gasket and my paperwork states:”(P/N STR-4NK35-10 or STR-4WM35-10EA) required.... Have no reference to those numbers. Now I will say that the LEDs I installed came from Larson lights (google them) and fit perfect. They are a predominant agricultural lighting source but fit well and really light the road. Do not get the trapezoidal bulbs if you look into them. Go with the spots.
RollinWoody Posted September 16, 2019 Author Posted September 16, 2019 One question. What Yamaha housings do you have? They made two driving light housings. One for the RSV and the other for the rest of the field. The RSV housing has the horizonal bolt and the others have a vertical bolt. I have the bezel with horizonal bolt on mine. The LED light sets in the bucket and the foam spacer in the bezel to hold everything tight. If you have the bezel with the vertical bolt you will have problems getting things lined up. The LED lamps that you have are they they the Yamaha "focused beam with Angel eye halo " ?
RollinWoody Posted September 16, 2019 Author Posted September 16, 2019 I purchased the led passing lamps to replace original sealed beams for my bike but unfortunately it seems there is an issue with the "bezel " or size of the bucket not sure if i need to replace with "STR-4NK35-10-00" ? Are they the same bucket or am I missing something?? I can squeeze it in but without the rubber surround gasket that is attached.... Thanks I finally found my answer from a seller : "LED Passing lamp retro fit kit for Yamaha cruisers that currently have H3 driving lights. Does NOT fit the bucket from sealed beam passing lamps." ........................................
Sylvester Posted September 16, 2019 Posted September 16, 2019 At least you have an answer. That is better than not knowing.
slowrollwv Posted September 17, 2019 Posted September 17, 2019 The LED lamps that you have are they they the Yamaha "focused beam with Angel eye halo " ? Sorry I have been off for a couple days. No mine are not from Yamaha. Mine are the Truck-Light Phase 6 LEDs. I did add Halo rings after the lights.
