Tiresmoking Posted July 21, 2018 Posted July 21, 2018 Does anyone know what size o-ring I need to put on the tube that goes across the front of the motor to into the thermostat housing?it had one in it then covered with jb weld. I want it done right. I didn’t do it bought the bike that way. Thanks in advance
SpencerPJ Posted July 21, 2018 Posted July 21, 2018 I am not sure which o-ring you are asking, but here is a link to a parts break down, and when you select your bike and find your part and part#, Google the part number and I bet you find your answer. https://www.yamahasportsplaza.com/oemparts/c/yamaha_motorcycle_1984/parts
Tiresmoking Posted July 21, 2018 Author Posted July 21, 2018 It’s the metal tube that goes across in front of the motor that has the drain cock assy,it goes over to the thermostat housing. I couldn’t find it on that website. You can see the the tube and housing under the radiator section. But just not a good enough picture
