wrscomncents Posted April 24, 2018 #1 Posted April 24, 2018 Maybe someone can help me with this. While going through my checklist of maintenance items while putting my bike back together I decided to look up the ignition timing procedure. I went to the manual and started reading the procedure. To my surprise at the end of the procedure I find out that the timing is not adjustable. So my question is, is it necessary to check the timing at all? Would checking the timing be more of a trouble shooting procedure? I currently do not have a timing light and really don't want to buy one if the timing cannot be adjusted anyway. Thanks.
crowrod Posted April 24, 2018 #2 Posted April 24, 2018 wrscomncents said: Maybe someone can help me with this. While going through my checklist of maintenance items while putting my bike back together I decided to look up the ignition timing procedure. I went to the manual and started reading the procedure. To my surprise at the end of the procedure I find out that the timing is not adjustable. So my question is, is it necessary to check the timing at all? Would checking the timing be more of a trouble shooting procedure? I currently do not have a timing light and really don't want to buy one if the timing cannot be adjusted anyway. Thanks. The only time I ever saw it mentioned is when doing a valve adjustment, but there is no way to adjust timing, so I would say no
wrscomncents Posted April 24, 2018 Author #3 Posted April 24, 2018 Yeah that's what I'm thinking also. Well I guess it saves me the cost of a timing light. Thanks.
Rafterd Posted April 25, 2018 #4 Posted April 25, 2018 Even if you had a timing light and the timing was off, you still can’t adjust it.
BlueSky Posted April 26, 2018 #5 Posted April 26, 2018 The timing does advance when the engine is revved. You could confirm that it is indeed advancing. But the bike would be low on hp if that was the case. Timing check is briefly mentioned in this maintenance video.
