Jski5669 Posted March 22, 2018 Share #1 Posted March 22, 2018 ok, next issue, i now have all 4 cylinders firing after having to replace 2 ignition coils. now when i open the throttle up past 1/2, it sounds like machine gun going off and it refuses to accelerate any more. i've synced the carbs, and tried the idle mixing screw. tried at range of 1 1/2 turns out all the way to 3 at 1/4 turn increments. once again, all help is appreciated. one thing while i noticed was the main jets were not set up like i've read on here. the PO had 122.5's on the right side vs the left. so i switched them so 122.5 on the left, 120 front right, and 117.5 back right. Link to comment Share on other sites More sharing options...
paysaw Posted March 22, 2018 Share #2 Posted March 22, 2018 You might want to check your spark plug wiring and cylinder firing.You might have things reversed.Your carbs could have problems too. Link to comment Share on other sites More sharing options...
Flyinfool Posted March 23, 2018 Share #3 Posted March 23, 2018 Check that correct wire on the primary side is plugged into each coil and that each coil is to the correct spark plug. Link to comment Share on other sites More sharing options...
bongobobny Posted March 23, 2018 Share #4 Posted March 23, 2018 If everything is wired up correctly, then the next thing I would suspect is your TPS... Link to comment Share on other sites More sharing options...
Jski5669 Posted March 24, 2018 Author Share #5 Posted March 24, 2018 had the ignitor coils wired backwards. SMH. thanks for the help! Link to comment Share on other sites More sharing options...
bongobobny Posted March 24, 2018 Share #6 Posted March 24, 2018 Hey, defecation occurs... Link to comment Share on other sites More sharing options...
