Mad Dog Posted February 18, 2017 Share #1 Posted February 18, 2017 Putting this in and ran into a couple of issues. Well, actually a question and an issue, which is a separate post. The question is, does this fit in the same spot as the OEM pump came out of? If not, where did you relocate it to? Thank you all as always. Mike Link to comment Share on other sites More sharing options...
Marcarl Posted February 18, 2017 Share #2 Posted February 18, 2017 Depends on which one you got. Last year I replaced a fuel pump on Dogmans bike but it wasn't a Facet I don't think. It did go in but was a tight fit and need a little re-routing of one of the lines I think. Link to comment Share on other sites More sharing options...
2WHEELSFORME Posted February 20, 2017 Share #3 Posted February 20, 2017 I put mine in the same spot but could only use one bolt instead of two. It also required a few small pipe fittings to turn the in or out (can't remember witch) into the direction needed. I think it was like two 1/8 inch street ells and maybe a nipple and hose to pipe connector or two. Going on memory the stock unit in and out were side by side and the F was on opposite sides requiring the small pipe fitting but yes it did mount in the same spot. Link to comment Share on other sites More sharing options...
Mad Dog Posted February 20, 2017 Author Share #4 Posted February 20, 2017 I put mine in the same spot but could only use one bolt instead of two. It also required a few small pipe fittings to turn the in or out (can't remember witch) into the direction needed. I think it was like two 1/8 inch street ells and maybe a nipple and hose to pipe connector or two. Going on memory the stock unit in and out were side by side and the F was on opposite sides requiring the small pipe fitting but yes it did mount in the same spot. Thank you Link to comment Share on other sites More sharing options...
