mralex714 Posted September 7, 2016 Posted September 7, 2016 I was doing some other things on my 86 and noticed the trunk was loose and rocked back and forth a lot. Upon further inspection I found the 2 forward mounts broken. I removed the trunk and found the back of the trunk was cracked from completely across from the rear 2 mount points. I'm guessing the front issue led to the rear issue. Wife never mentioned it was loose. Check your bike it looks like one side had been repaired before.
yamagrl Posted September 8, 2016 Posted September 8, 2016 Do you have a replacement mount or do you need one?
bongobobny Posted September 8, 2016 Posted September 8, 2016 Yup!! I've seen worse, usually fixed with welding, MacGuiver'ing using fat fender washers...
mralex714 Posted September 8, 2016 Author Posted September 8, 2016 Do you have a replacement mount or do you need one? I found one on ebay that wasn't broken. I think I will have it beefed up at a machine shop. Thanks
Condor Posted September 8, 2016 Posted September 8, 2016 I had the two tabs that take the passenger grips snapped clean off on the '91 plus the two forward tab on the frame. Welding took care of the problem. $5 bucks. Never could figure out what would cause that...?? No other damage anywhere...
mralex714 Posted September 18, 2016 Author Posted September 18, 2016 I found one on ebay that wasn't broken. I think I will have it beefed up at a machine shop. Thanks I saw 5 or 6 and all but one had a broken right tab. The one I bought looked good but when I got it the right tab was cracked.
