clav_guy Posted August 8, 2016 Share #1 Posted August 8, 2016 So I went to my local Yamaha dealer and ordered two sets of LED directional lights for my 2006 RSV. They sold me a Rear LED conversion kit and a Front LED conversion kit from Big Bike Parts and the load equalization resistors from Bike Master (#26-6242) I installed everything according to the directions. Prior to installing the equalization resistors, I did a quick test and the blinkers were flashing really fast. After installing the resistors they are still blinking too fast. Not "machine gun" fast as a previous poster said but faster than what I like. Any ideas as to what my next step might be? Thanks in advance Pierre Link to comment Share on other sites More sharing options...
XV1100SE Posted August 8, 2016 Share #2 Posted August 8, 2016 You need one load equalizer for the front and one for the back. With my Custom Dynamics run/turn/brake (rear - no LED's on the front) I had to add a second load balancer/resister. Then my lights worked properly. I'll assume you have load resistor on the front lights as well as the rear.....Eliminate where the issue is by putting incandescent bulbs in the front and see if the blinking goes back to normal. If not, repeat the test with the rear. If both tests don't resolve the problem, then hook up both load resisters to the rear, incandescent bulbs in front. If that fixes the problem, then try the LED's in front. If they start flashing fast....then you need to double up the resistors on the front too. Link to comment Share on other sites More sharing options...
Bert2006 Posted August 8, 2016 Share #3 Posted August 8, 2016 When I did mine I installed a load equalizer for each corner and they work great. Self cancelling and 4 way's work well also. Link to comment Share on other sites More sharing options...
Flyinfool Posted August 8, 2016 Share #4 Posted August 8, 2016 Can you read the markings on your load equalizers? or post a pic of them. they might just be the wrong value. Link to comment Share on other sites More sharing options...
