snyper316 Posted July 27, 2016 Share #1 Posted July 27, 2016 Ok does anyone have suggestions for getting new throttle cables for my Bike... They seem to have discontinued yet another thing that well it just dont make sense to me, Is it possible to get after markets? It no biggy if I cant get them but just in shock that so many common sense parts are no longer available for this Bike.. or could i possible just get everything for the 89 model and just redo it? Link to comment Share on other sites More sharing options...
gaj1917 Posted July 27, 2016 Share #2 Posted July 27, 2016 I just checked PartShark. They have Cables #3 and #4 for $22 and $17, respectively, for the '84, but none for '83. I wonder what would be so different between '83 and '84? Link to comment Share on other sites More sharing options...
snyper316 Posted July 27, 2016 Author Share #3 Posted July 27, 2016 I just checked PartShark. They have Cables #3 and #4 for $22 and $17, respectively, for the '84, but none for '83. I wonder what would be so different between '83 and '84? I need pusher cable or return cable but since that one broke last year sometime i figured might as well replace them all... and i dont know this reminds me of a car i owned once i could only use part from that year and make of car... Link to comment Share on other sites More sharing options...
snyper316 Posted July 27, 2016 Author Share #4 Posted July 27, 2016 I need pusher cable or return cable but since that one broke last year sometime i figured might as well replace them all... and i dont know this reminds me of a car i owned once i could only use part from that year and make of car... Btw the conjuction box is different its same as the 89 Link to comment Share on other sites More sharing options...
Prairiehammer Posted July 27, 2016 Share #5 Posted July 27, 2016 I just checked PartShark. They have Cables #3 and #4 for $22 and $17, respectively, for the '84, but none for '83. I wonder what would be so different between '83 and '84? The 1983 XVZ12 had no factory cruise control and thus did not have the "five into one" rotary connector. The cable ends went into a "slider" instead. The cable ends were longer cylindrical terminations instead of the "barrel" connectors. The later cables have the barrel at both ends. The 1983 Slider: Later model union: Link to comment Share on other sites More sharing options...
snyper316 Posted July 27, 2016 Author Share #6 Posted July 27, 2016 The 1983 XVZ12 had no factory cruise control and thus did not have the "five into one" rotary connector. The cable ends went into a "slider" instead. The cable ends were longer cylindrical terminations instead of the "barrel" connectors. The later cables have the barrel at both ends. [ATTACH=CONFIG]106597[/ATTACH] The 1983 Slider: [ATTACH=CONFIG]106598[/ATTACH] Later model union: [ATTACH=CONFIG]106599[/ATTACH] so if i switched that box out do you think it would work.... I Checked the part numbers so the only thing that seems to stop me is this little box which those peices in that box are fairly cheap at least thru part shark... and those cables are used all the way into 90s model bikes the grips same part number the throttle rod same thing so the only thing that would stand in my way is this box and does it go in the same place as my slider as i know there is plenty of room for it to be there.... Link to comment Share on other sites More sharing options...
Prairiehammer Posted July 27, 2016 Share #7 Posted July 27, 2016 Yes, if you swapped the early straight line slider for the later rotary union, you could then use the later, available cables. Link to comment Share on other sites More sharing options...
snyper316 Posted July 27, 2016 Author Share #8 Posted July 27, 2016 But i would also like to update the grips to black and silver with the cushy grip with a sort of point at the end or heck maybe even tassles Link to comment Share on other sites More sharing options...
Prairiehammer Posted July 27, 2016 Share #9 Posted July 27, 2016 But i would also like to update the grips to black and silver with the cushy grip with a sort of point at the end or heck maybe even tassles Suit yourself. Whatever floats your boat, but the cables would not be different, regardless of grips. Link to comment Share on other sites More sharing options...
snyper316 Posted July 27, 2016 Author Share #10 Posted July 27, 2016 I know but just dont know where to get grips lol i want to get ones that work and not something for SHOOTZOOKI that dont work lol I was kinda asking for idea where to look Link to comment Share on other sites More sharing options...
Prairiehammer Posted July 27, 2016 Share #11 Posted July 27, 2016 I know but just dont know where to get grips lol i want to get ones that work and not something for SHOOTZOOKI that dont work lol I was kinda asking for idea where to look While most aftermarket sources do not specifically offer grips for the First Gen Venture anymore, those that are offered up as Honda GL1500 replacements will work perfectly on the First Gen Venture. Link to comment Share on other sites More sharing options...
gaj1917 Posted July 27, 2016 Share #12 Posted July 27, 2016 I have Kuryakyn grips on my '84. Very nice. Do an eBay search or Google search and I'm sure you will find lots. Link to comment Share on other sites More sharing options...
snyper316 Posted July 27, 2016 Author Share #13 Posted July 27, 2016 While most aftermarket sources do not specifically offer grips for the First Gen Venture anymore, those that are offered up as Honda GL1500 replacements will work perfectly on the First Gen Venture. Correct me if im wrong but thats a Godwing Link to comment Share on other sites More sharing options...
Flyinfool Posted July 27, 2016 Share #14 Posted July 27, 2016 Correct me if im wrong but thats a Godwing Nothing like God about it. But it is a GoldWing..... .... and the grips do fit on a MKII. Link to comment Share on other sites More sharing options...
snyper316 Posted July 27, 2016 Author Share #15 Posted July 27, 2016 Nothing like God about it. But it is a GoldWing..... .... and the grips do fit on a MKII. Aint that the truth LMAO I dont know if its just me but i seen one going down the road and i thought ITS GOD AWFUL UGLY:shock3: but i guess ppl like the style but i would never and that was a typo my bad lol Link to comment Share on other sites More sharing options...
ChurchBuilder Posted July 27, 2016 Share #16 Posted July 27, 2016 I probably have 83 cables if you still need them. PM me if you want them and I'll go look Sent from my SCH-I545 using Tapatalk Link to comment Share on other sites More sharing options...
