DblTrbl Posted July 12, 2016 Posted July 12, 2016 Just did an oil change on the RSV. Put in fresh oil, ran if a few minutes to get oil into filter. Waited about 10 min and checked the oil level. It was just above the minimum line so I added a bit more. Went back about an hour later and the oil level is at the top of the window. Any suggestions about getting some of the oil out without having to remove the plug (I just put a new compression washer)??? I may try to suction some out from going thru the top (fill hole)....
2WHEELSFORME Posted July 12, 2016 Posted July 12, 2016 Wow a new compression washer. Must save that item. They are reusable you know if you don't have another one or they are too texpensive where you live. Crack the drain bolt let a little our and retighten. You'll never know the difference. Very important not to run with it over filled.
Gary N. Posted July 12, 2016 Posted July 12, 2016 You could remove the filter and dump it out. Probably just about the right amount. Keep the level 1/2 way between the lines on the sight glass or you'll be seeing drips under the bike.
RedRider Posted July 12, 2016 Posted July 12, 2016 Go for a 1000 mile ride and it will balance out on its own. RR
bongobobny Posted July 12, 2016 Posted July 12, 2016 Yah!! Because oil is viscous it takes a loooong time to drain into the pan.. Best time to check the level is after the bike sets overnight... As stated compression washers are NOT like crush washers, you use them over and over! Just unscrew the drain plug to let a little out, say a half pint, and get on with life! Red Rider's suggestion will actually work, you won't kill your engine, but you sure will get a lot of oil all over the place, like in your airbox, down the drain hoses, etc... I don't advise it, I'm sure he was being facetious.
DblTrbl Posted July 12, 2016 Author Posted July 12, 2016 Yah!! Because oil is viscous it takes a loooong time to drain into the pan.. Best time to check the level is after the bike sets overnight... As stated compression washers are NOT like crush washers, you use them over and over! Just unscrew the drain plug to let a little out, say a half pint, and get on with life! Red Rider's suggestion will actually work, you won't kill your engine, but you sure will get a lot of oil all over the place, like in your airbox, down the drain hoses, etc... I don't advise it, I'm sure he was being facetious. it is a crush washer...first time I ever used one.
DblTrbl Posted July 12, 2016 Author Posted July 12, 2016 thanks for the response... glad to see I'm not the only smart ass on the site!! LOL
KIC Posted July 12, 2016 Posted July 12, 2016 You could remove the filter and dump it out. Probably just about the right amount. Keep the level 1/2 way between the lines on the sight glass or you'll be seeing drips under the bike. That's what I would do...
Venturous Randy Posted July 12, 2016 Posted July 12, 2016 Were you checking the oil with the bike level, or was it sitting over on the side stand? Randy
bongobobny Posted July 12, 2016 Posted July 12, 2016 He has a trike, so it's always level, but good point Randy...
DblTrbl Posted July 13, 2016 Author Posted July 13, 2016 as Bob said, I have a trike and it was on a level surface (in the basement). I have change oil before but this is the first time I have over filled.
bongobobny Posted July 13, 2016 Posted July 13, 2016 Wouldn't ya know it Dennis, changed MY oil yesterday and what did I do?? You guessed it! Ya jinxed me I say, ya jinxed me...
DblTrbl Posted July 14, 2016 Author Posted July 14, 2016 Wouldn't ya know it Dennis, changed MY oil yesterday and what did I do?? You guessed it! Ya jinxed me I say, ya jinxed me... Damn, Sorry Bob!! Well I got a small piece of tubing and I syphoned some oil out. All is fine now. I obviously didn't get all the old oil out because I could see the new oil setting on top of the darker oil thru the window. I will change oil again after the Ontario trip and before going to Maggie Valley. When are you heading to Minden? Are you crossing at Niagra?
bongobobny Posted July 14, 2016 Posted July 14, 2016 No, crossing at Fort Erie/Buffalo Wednesday night and am spending overnight with Wizard765 in Caledonia Ontario. We are departing there Thursday morning with them to take the scenic route up to Mindon avoiding all the cities on the way up there. Not sure how many will be in this group, but will see you in Mindon Thursday afternoon...
