Wilzhere Posted May 18, 2016 Share #1 Posted May 18, 2016 does anyone have a pic or know the location????Grrrr Wil Link to comment Share on other sites More sharing options...
mralex714 Posted May 18, 2016 Share #2 Posted May 18, 2016 does anyone have a pic or know the location????Grrrr Wil They are the floats inside the resivoirs. Link to comment Share on other sites More sharing options...
bongobobny Posted May 18, 2016 Share #3 Posted May 18, 2016 It's inside the master cylinder reservoir! It's a coil core with a plastic float that has a magnet on it surrounding the coil... Link to comment Share on other sites More sharing options...
bongobobny Posted May 18, 2016 Share #4 Posted May 18, 2016 Mr. Alex, you type faster than me... Link to comment Share on other sites More sharing options...
Wilzhere Posted May 18, 2016 Author Share #5 Posted May 18, 2016 im trying to elimite the warning on cms both have been change to after market type resivors. i see in wiring diagram a sensor that needs to be jumpered to eliminate warning on cms thanks Wil Link to comment Share on other sites More sharing options...
bongobobny Posted May 18, 2016 Share #6 Posted May 18, 2016 Yup! There was/is a 4 pin connector that the brake light switch plugs into that also connects the sensor if memory serves me right, but then again I've forgotten a lot of stuff lately... Haven't worked on my 1st gen in years! Link to comment Share on other sites More sharing options...
Wilzhere Posted August 24, 2016 Author Share #7 Posted August 24, 2016 does anyone have a pic or know the location????Grrrr Wil is there a way to bypass the sensors so the CMS does not see that the sensors are not there? for the brake lights? like the sensor mod for the battery which i have done successfully? also trying to find and maybe mod the oil level sensor? any help people? also found wires disconnected from CMS i believe???? yel/red to yel/green.......green/green/red is this an attempt to remove reserve lighting unit? my headlights and hi/lo switch and indicator do work Thanks Wil Link to comment Share on other sites More sharing options...
yamagrl Posted August 28, 2016 Share #8 Posted August 28, 2016 im trying to elimite the warning on cms both have been change to after market type resivors. i see in wiring diagram a sensor that needs to be jumpered to eliminate warning on cms thanks Wil Simple... on the back of the cmu simply ground out the W/B (White/Black) wire. The screen shot below is from the 83 Simplified Diagram. Link to comment Share on other sites More sharing options...
yamagrl Posted August 28, 2016 Share #9 Posted August 28, 2016 is there a way to bypass the sensors so the CMS does not see that the sensors are not there? for the brake lights? like the sensor mod for the battery which i have done successfully? also trying to find and maybe mod the oil level sensor? any help people? also found wires disconnected from CMS i believe???? yel/red to yel/green.......green/green/red is this an attempt to remove reserve lighting unit? my headlights and hi/lo switch and indicator do work Thanks Wil Check out this thread. It might help. http://www.venturerider.org/forum/showthread.php?42017-1983-first-gen-HID-installation&p=399353#post399353 Link to comment Share on other sites More sharing options...
cowpuc Posted August 28, 2016 Share #10 Posted August 28, 2016 Simple... on the back of the cmu simply ground out the W/B (White/Black) wire. The screen shot below is from the 83 Simplified Diagram. [ATTACH=CONFIG]107088[/ATTACH] Dag nabbit that Yamigrl sure knows how to make complicated matters livable and understandable - even for lop eared varmints like me .. My final answer would have been a hunk of electrical tape stretched over that flashing red light cause I have fired a few shots at that sneaky bugger too GOOD, EASY TO UNDERSTAND AND QUALITY INFO YAMAGRL!! :sign Rock On::sign Rock On: Link to comment Share on other sites More sharing options...
