Zzyzx Posted June 2, 2015 Posted June 2, 2015 Need some advice from those who have run the E-3 front tire. I mounted a new Dunlop E-3 front tire on my RSV following the directional arrow on the tire and rim but...looks like the tread is running in the opposite direction than I am used to with the old D-404's. It is also the reverse from the rear tire which is a E-2 Is this correct rotation shown in the pictures or do I need to reverse it? My concern is in rain would this not bring water toward the center of the tire and how this would corner or, am I just overthinking the factories pattern design. Thanks in advance.
Rmar Posted June 2, 2015 Posted June 2, 2015 I had Michelin Commander 11 s on the Road star I had they had basically the same thread pattern. my thought were the same as yours. They handled well in some very hard downpours. One time in the mountains of NC. I was totally surprised at how well they did. Never lost any traction even with water running across the road.
slowrollwv Posted June 2, 2015 Posted June 2, 2015 I had the same thought as you. I just put an E3 on mine. Came home from Don's MD in the pouring rain. No problem with the tires.
Karaboo Posted June 2, 2015 Posted June 2, 2015 This is what my E3 looks like after 7800 miles on front of a 1st gen. Pretty sure the rotation is right. Handles OK. Shinko handled better, but was gone by 9000 miles. Rear only lasted 7000. I am hoping to double that with the E3's. Twice the price, so I better get twice the mileage.
Zzyzx Posted June 3, 2015 Author Posted June 3, 2015 Thanks everyone! Looks like this was mounted correctly. Ride Safe!
JohnT Posted June 3, 2015 Posted June 3, 2015 This season is my first use of the E3 tires on my 1st Gen. They seem so far to ride and handle great. I do still have my high speed weave though.(100 mph +) I had been running 36 psi front and 40 psi in the rear. Reading my owners manual I found recommended front psi should be 32 and rear 32 for high speed running and 36 to 40 psi in the rear for 2 up and / or carrying a heavy load. I am trying to tame the high speed weave. 2 good mechanics find nothing wrong with fall away, forks,alignment, or anything else but for a slightly warped rear brake rotor. (can NOT find a replacement rear rotor) Any thoughts on the tire pressure idea?
Mike G in SC Posted June 3, 2015 Posted June 3, 2015 (edited) Tire is mounted correct,,, if that is the left side. My RSV with a 3 week old tire,,, but already has over 3K miles from a SC to Maine lobster run. I got 26K miles on the last one, and it had a lot of tread left. Sorry bout the sidewise pic, could not get it to go away..... Edited June 3, 2015 by Mike G in SC
