KISA Posted May 25, 2015 #1 Posted May 25, 2015 Where the pipe No. 44 is connected? From above only carburetors...
Marcarl Posted May 25, 2015 #2 Posted May 25, 2015 Connected between #32 (in the joint of the cooling system under the right side cover, 3 hoses together there on same joint) and cover # 37 which lays between the 2 cylinder banks.
Prairiehammer Posted May 25, 2015 #3 Posted May 25, 2015 Where the pipe No. 44 is connected? From above only carburetors... [ATTACH=CONFIG]99486[/ATTACH] Number 44 tube goes from the left front corner of the airbox (drain for accumulated oil in airbox) to the "T" in the crankcase vent hose.
Prairiehammer Posted May 25, 2015 #4 Posted May 25, 2015 Connected between #32 (in the joint of the cooling system under the right side cover, 3 hoses together there on same joint) and cover # 37 which lays between the 2 cylinder banks. You described #49 hose layout. He asked about #44 hose.
Marcarl Posted May 26, 2015 #6 Posted May 26, 2015 You described #49 hose layout. He asked about #44 hose. Ok, so now he knows about #32 as well,,,, oooppps!!! lucky I mentioned the numbers eh?
