Du-Rron Posted February 14, 2015 Posted February 14, 2015 I have already done the bit where you take the fairing apart and grease all the radio connections with dielectric. I was riding around yesterday and my Ipod stopped playing. What the heck?!?!? Spent some time re-taking the fairing apart, unplugged, replugged, nothing worked. The Ipod would not work. Went to the left saddlebag where the Ipod is stored and was replugging and fiddling with the Ipod when I noticed out of the corner of my eye... "The junk in my saddlebag had unplugged the other end of the Ipod cable from the AMP breakout box!!!! I could have saved about an hour of fiddling if I had checked here first. Plugged the cable back into Port #1 of the AMP breakout box. Ipod works again.
djh3 Posted February 16, 2015 Posted February 16, 2015 Can you tell me what the model number or manufactures number is on your i-pod simple thingy. Trying to see if a fellow could source one without going thru Yammay
vzuden Posted February 17, 2015 Posted February 17, 2015 The iSimple part # is 1BM-H81C0-V2. (Audio set kit). That would be the Yamaha number and as I am looking it mine there is a label with the number AZ2111. It is called "iSimple Gateway" media interface.
Du-Rron Posted February 17, 2015 Author Posted February 17, 2015 Does a picture help along with VZUDEN's info?
djh3 Posted February 17, 2015 Posted February 17, 2015 Thanks fellows. Maybe can figure a way to work around having to buy thru Yamaha.
