I know wrong bike. but tried its form could not even get in. had to replace the wire harness as burned in the head light bucket there is a light green wire solid color only one terminal no match any where. what terminal tool removes the bigger plugs[ bullet style]
sorry hit wrong button the head light wont light and the tac moves around with key turned on. haven't bought turn signal relays as they are melted. any one know what wires I could hook up to start bike. it is a virago 750 1981. :fishin:
I got most of the wires hooked up yesterday. going to doctor up the battery with ebson salt today. not enough power to energize relays. have to wait till spring to buy rest of parts. this bike burned about two years ago. carb float stuck. have to find a seat, tank , both t/s relays, tool box rear housing, I have bought every thing else already. doing this bike to have some thing to ride. while the other one is fighting me. was going to disconnect the safety system on the venture and take for a drive to find out whats acting up. but have to wait for ice behind garage to melt. that way will know electric or fuel problem.
I had an XJ750 Seca. Pretty sure I still have the wiring diagram somewhere. Will have to look for it if you still want it
have every thing wired up now. color code was off on two wires. my biggest problem was a bad relay. took relay apart and manually activated it completed circuit bike turned over and had spark have to figure out what wire fires relay and what two complete circuit. don't make this relay any more. time to update it.
