Is the left side transmission cover the same part for both the XVZ12 (1983-1985)and the XVZ13 (1986-1993) or are does each motor have a different-sized cover?
Thanks,
Richard:322:
The 83-85 is about 1/2" narrower than the 86-93 version. The motor block has no change in this area over the years.
Difference is due to changed stack-up height of the clutch pack when changed from 6 helical springs to the bevel spring.
You can put a 86-93 clutch cover on the 83-85 motor/clutch combo. But not the other way. I discovered this when upgrading clutch about 4 years ago.
Gary
Crap, I need to work on reading comprehension.
All side covers, except clutch, are interchangeable from 83-93.
Gary
  • 3 weeks later...
Hello Gary,
Can the stator cover/housing be swapped between the 1984 XVZ 1200aand the 1988 XVZ 1300?
THANKS,
RICHARD
Gary
Is the Stator Housing the same for the 1984 and 1988 VR's and therefore can be transferred between the two bikes?
Thanks,
Richard
Richard,
As Gary said, all the engine case covers are interchangeable with the exception of the clutch cover.
