spartikus Posted September 30, 2014 Share #1 Posted September 30, 2014 I have tried to research this bot not quite clear yet. The flasher/hazard relay can be replaced with a standard 12V flasher relay from canadian tire? Use the electronic one not the thermal one as they require load on the wire. Thanks in advance. Link to comment Share on other sites More sharing options...
dingy Posted September 30, 2014 Share #2 Posted September 30, 2014 I have tried to research this bot not quite clear yet. The flasher/hazard relay can be replaced with a standard 12V flasher relay from canadian tire? Use the electronic one not the thermal one as they require load on the wire. Thanks in advance. Possibly on an 83. From 84 on, the flasher relay was combined with the start circuit relay. This would have most likely been a specific application relay that would have limited use outside Yamaha. Gary Link to comment Share on other sites More sharing options...
spartikus Posted September 30, 2014 Author Share #3 Posted September 30, 2014 Really Gary? The electrical diagram just shows straight up connection to hazard and turn signals. I dont see the tie in to starter circuit. I'll go relook. Would utterly shock me though. Link to comment Share on other sites More sharing options...
spartikus Posted September 30, 2014 Author Share #4 Posted September 30, 2014 I stand corrected.. :/ Hmm. Could probably yank the wires required and just wire in a standard relay. Will do some more research. thanks again Link to comment Share on other sites More sharing options...
MikeWa Posted October 1, 2014 Share #5 Posted October 1, 2014 I have tried to research this bot not quite clear yet. The flasher/hazard relay can be replaced with a standard 12V flasher relay from canadian tire? Use the electronic one not the thermal one as they require load on the wire. Thanks in advance. Why would you want to go with a 12v auto flasher? Mike Link to comment Share on other sites More sharing options...
spartikus Posted October 1, 2014 Author Share #6 Posted October 1, 2014 Availability and they operate on the exact same principle. IMO it is an easy wiring job but dont want to frankenstein the bike for future owners to try and figure out. Finding the relay unit is still available $180 from most bike parts suppliers but $100 from online vendors. + $30-$50 shipping Link to comment Share on other sites More sharing options...
Flyinfool Posted October 1, 2014 Share #7 Posted October 1, 2014 If you do wire in an external flasher, you will also loose the self canceling feature since that is also inside of that same Flasher/Start relay module. I have thought of trying to disassemble an OEM module to see if it possible to retain the self cancel, but wire in an electronic flasher that will flash correctly regardless of load. But I need to find a OEM flasher with a bad start relay, I hate to chop up a good one. Link to comment Share on other sites More sharing options...
MikeWa Posted October 1, 2014 Share #8 Posted October 1, 2014 Got mine used on e-bay for $20.00. I Googled the Denso part number. But for 200 dollars I feel your pain. Mike Link to comment Share on other sites More sharing options...
Neil86 Posted October 1, 2014 Share #9 Posted October 1, 2014 Try the contact in Calgary I gave you....I'm sure he has a few. Link to comment Share on other sites More sharing options...
spartikus Posted October 1, 2014 Author Share #10 Posted October 1, 2014 Good call Neil thanks. Im coming down with a cold and not thinking clearly heh. Hope your cold cleared up. Lotta nasty going around this Fall with the crazy weather. Link to comment Share on other sites More sharing options...
Neil86 Posted October 1, 2014 Share #11 Posted October 1, 2014 getting there...but its been a week. Link to comment Share on other sites More sharing options...
