Riderduke Posted September 5, 2014 Share #1 Posted September 5, 2014 Its been happening for a while now......My over drive Light(5th gear green light) doesn't come on right away when I shift into 5th gear..... Sometimes it doesn't come on at all. Anyone have an Idea what wrong. Its not a big deal but I just ordered new tires, so when I go to put them on I might find the time to rectify the problem...... Link to comment Share on other sites More sharing options...
Neil86 Posted September 6, 2014 Share #2 Posted September 6, 2014 While in 5th with the light not showing, trying setting the cruise....if it won't set, I would find the connector for the neutral switch and test the wires down to connector and the switch itself. Link to comment Share on other sites More sharing options...
Riderduke Posted September 6, 2014 Author Share #3 Posted September 6, 2014 Cruse control works fine......with or with-out the light I just realized that I posted in the 1st gen section this should have been in the 2nd gen section. I have a 2004 RSV......sorry:whistling: Link to comment Share on other sites More sharing options...
Freebird Posted September 6, 2014 Share #4 Posted September 6, 2014 Just moved it for you. Link to comment Share on other sites More sharing options...
Yammer Dan Posted September 6, 2014 Share #5 Posted September 6, 2014 Cruse control works fine......with or with-out the light I just realized that I posted in the 1st gen section this should have been in the 2nd gen section. I have a 2004 RSV......sorry:whistling: Dreaming again..... Link to comment Share on other sites More sharing options...
Beau-Kat Posted September 7, 2014 Share #6 Posted September 7, 2014 Its been happening for a while now......My over drive Light(5th gear green light) doesn't come on right away when I shift into 5th gear..... Sometimes it doesn't come on at all. Anyone have an Idea what wrong. Its not a big deal but I just ordered new tires, so when I go to put them on I might find the time to rectify the problem...... Got the same issue. Comes and goes on occasion. Currently not working. May work tomorrow, who knows? Cruise works fine. Link to comment Share on other sites More sharing options...
Condor Posted September 8, 2014 Share #7 Posted September 8, 2014 I'm not sure what a 2ndGen has because I've never had to deal with it yet, but on the 1stGen the gear indicator is located next to the clutch slave on the engine and may have a problem. You'll need to remove the middle gear cover to check it out... Maybe a 2ndGen has a different system, and if so, I'm sure someone will chime in.... Link to comment Share on other sites More sharing options...
86er Posted September 8, 2014 Share #8 Posted September 8, 2014 That is a really easy fix, David. If you can get to the 5th gear light, all you need to do is to pull it out and clean the connector really well. Next, clean the bulb socket really well , then remount the light.................. ...................... in a 1st Gen!!! After all, look where you posted . Link to comment Share on other sites More sharing options...
