Riderduke Posted September 5, 2014 Posted September 5, 2014 Its been happening for a while now......My over drive Light(5th gear green light) doesn't come on right away when I shift into 5th gear..... Sometimes it doesn't come on at all. Anyone have an Idea what wrong. Its not a big deal but I just ordered new tires, so when I go to put them on I might find the time to rectify the problem......
Neil86 Posted September 6, 2014 Posted September 6, 2014 While in 5th with the light not showing, trying setting the cruise....if it won't set, I would find the connector for the neutral switch and test the wires down to connector and the switch itself.
Riderduke Posted September 6, 2014 Author Posted September 6, 2014 Cruse control works fine......with or with-out the light I just realized that I posted in the 1st gen section this should have been in the 2nd gen section. I have a 2004 RSV......sorry:whistling:
Yammer Dan Posted September 6, 2014 Posted September 6, 2014 Cruse control works fine......with or with-out the light I just realized that I posted in the 1st gen section this should have been in the 2nd gen section. I have a 2004 RSV......sorry:whistling: Dreaming again.....
Beau-Kat Posted September 7, 2014 Posted September 7, 2014 Its been happening for a while now......My over drive Light(5th gear green light) doesn't come on right away when I shift into 5th gear..... Sometimes it doesn't come on at all. Anyone have an Idea what wrong. Its not a big deal but I just ordered new tires, so when I go to put them on I might find the time to rectify the problem...... Got the same issue. Comes and goes on occasion. Currently not working. May work tomorrow, who knows? Cruise works fine.
Condor Posted September 8, 2014 Posted September 8, 2014 I'm not sure what a 2ndGen has because I've never had to deal with it yet, but on the 1stGen the gear indicator is located next to the clutch slave on the engine and may have a problem. You'll need to remove the middle gear cover to check it out... Maybe a 2ndGen has a different system, and if so, I'm sure someone will chime in....
86er Posted September 8, 2014 Posted September 8, 2014 That is a really easy fix, David. If you can get to the 5th gear light, all you need to do is to pull it out and clean the connector really well. Next, clean the bulb socket really well , then remount the light.................. ...................... in a 1st Gen!!! After all, look where you posted .
