Mileage poll!
About 65k miles on my 09 RSV. (two up and trip traveler)
About 99k miles on my 06 RSTD. (my daily commute bike)
Both running fine.
But yeah, warranty stuff was shocks and fuel pumps on both.
Also on RSTD, stator and R/R and ignition switch. Neck bearing on RSTD not warranted.
Just rolled 125,000 miles last week on my 2000. Let's see, major problems ......
OEM shock went out at about 110,000 miles (I was living on borrowed time). Replaced with a Hagon.
Bearing went out in the final drive. Replaced with a take off from someone triking their Venture (CarbonOne IIRC).
Couple of clutches/springs.
That's about it. It has been pretty bulletproof.
Now, for a longer list, ask about the farkles and mods done.
RR
  • 4 weeks later...
Just curious, who has the most miles on their second gen venture and what major malfunctions if any have you experienced during your miles.
Just rolled 130,200 miles on my 2006 midnight that I purchased in 2008 (had 20,000 on it then)
Two rear shocks, on warranty replaced with Works shock
Clutch at 40,000, replaced with Barnett system
Fuel pump under warranty at 60K ish?
Whole radio unit under warranty at 60K (mechanic doing fuel pump broke it oops)
Neck bearings and swing arm bearings at 90K
Key switch, pickup coil and side stand relay (SCCR) at 124,135 miles (replaced the starter relay 'just because'..
NOW the bike has run so much better than ever before.. woot!
