Dale124 Posted July 26, 2014 #1 Posted July 26, 2014 Hi all. Yesterday I went to install my new yamaha headlight visor and found it seems way too big. The curve of the visor doesn't follow the curve of the headlight at all! The instructions that were with it say it is a 7" headlight visor for Yamaha Royal Star, and seem to show a completely different headlight assembly in the picture. For those of you that have installed your visor, does this sound like I have the wrong one? Dale.
Freebird Posted July 26, 2014 #2 Posted July 26, 2014 Sounds like you got a visor for the Royal Star and not the Royal Star Venture. Completely different headlight so I assume the visor is probably different also.
Venturous Posted July 26, 2014 #3 Posted July 26, 2014 What part number is it? Even if the right one... I do recall I had to work a LITTLE to get mine to fit. But if it seems WAY different.. probably wrong part.
MikeWa Posted July 26, 2014 #4 Posted July 26, 2014 Dale Without a part number it is impossible to tell if you have the correct visor. The one I installed on my Venture seemed a little large and had to be worked in. But you are saying way to big. So it sounds like a wrong part. Mike
Dale124 Posted July 26, 2014 Author #5 Posted July 26, 2014 Hi guys. Ok, the part number on the box is STR-4NK58-10. On the dealers price sticker, there is a -00 after the 10, and it says "Headlight VSR. V-Star". To me it seems like it would have to bend in a lot to actually fit into place. I did not want to attempt this and end up damaging it, then finding out its the wrong one. Dale
MikeWa Posted July 26, 2014 #6 Posted July 26, 2014 Wrong part "it says "Headlight VSR. V-Star". V-Star and Royal Star are different. Mike
Dale124 Posted July 26, 2014 Author #7 Posted July 26, 2014 Ok, don't be too hard on me, but I may be an idiot. I put the other visors on for the passing lamps and the turn signals, and thought I'd double check the headlight one. It does flex somewhat, so I attempted to put in on, and low and behold, it worked! I guess the part number must fit multiple bikes- in fact, it lists several models on the side of the box. Now, all is back together and looking sharp
