videoarizona Posted July 19, 2014 Share #1 Posted July 19, 2014 Drained oil...everything looked good. Took filter assembly off, but couldn't get filter out of it's home. Finally used the socket and turned the bolt, while holding filter. "screwed" right out. Underneath, one spring. Thought maybe a washer to go between filter and spring, but nada. My bike does not have an O-ring around the bolt outside, rather a seal...similar to the two seals on either side of, and part of, the filter. It wasn't leaking so I'll put all back the same way. Put some oil on filter O-ring and tightened up to spec. Note: The drain bolt was on tighter than 31ftlbs. No O-ring or gasket there either. I did test the oil warning light and it worked. Now to run the bike and see what happens... Not bad at all...although I'm still a bit intimidated laying under or near the bike. Funny, I've rebuilt engines before and crawled under cars for fun and to save a few bux, but this bike scares me...and I DID strap the center stand open to the bike frame so it wouldn't accidently fall off forward. Maybe getting to be an ole fart has something to do with it. I know I'm not invincible! Link to comment Share on other sites More sharing options...
Neil86 Posted July 19, 2014 Share #2 Posted July 19, 2014 Yes, there should be a washer between filter and spring...often they stick to filter and get lost when filter discarded. Link to comment Share on other sites More sharing options...
Flyinfool Posted July 19, 2014 Share #3 Posted July 19, 2014 I'm with you on working under the bike. Cars are not an issue because I know that no matter how aggressive I get with a wrench under there, I can not flip the car over. I would bet that I can pull hard enough to tip a bike over. Link to comment Share on other sites More sharing options...
videoarizona Posted July 19, 2014 Author Share #4 Posted July 19, 2014 Thought so... about the washer. Well...next time I'll put one on there. No leaks during run up...but have to wait until the weather cools down so I can go for a real ride and see if I did everything right. BTW, the Fram type filter did not have O-rings with it but the Wix 24933 did. So got two of those.. Thanks, guys.... Link to comment Share on other sites More sharing options...
