Geobob Posted May 13, 2014 Posted May 13, 2014 There is a second line off the rear of the tank. I assume it is a vent line and can just be removed without fear of fuel draining out everywhere. Can anyone confirm this. The fuel line appears to have a petcock that can be turned off so it make sense that the rear line is just a vent since there is no valve.
videoarizona Posted May 13, 2014 Posted May 13, 2014 I have the VSTAR950. Similar. Fuel injected. Go here> http://vstar1300.pbworks.com/w/file/56501226/____Yamaha_1300vstarmanual.pdf download manual... david
Gray Ghost Posted May 13, 2014 Posted May 13, 2014 From the Service Manual. The text for the picture is: Order Part Qty Remarks 1 Fuel Tank Bolt 2 2 Rt Side Panel 1 3 Lt Side Panel 1 4 Fuel Sender Coupler 1 Disconnect 5 Fuel Cock Hose 1 Before removing turn fuel cock to OFF 6 Air Vent Hose 1 7 Fuel Tank Overflow Hose 1 8 Fuel Tank Breather Hose 1 Fuel tank to hose joint 9 Fuel Tank 1 10 Fuel Sender 1 11 Fuel Cock 1
