Head Light is very dim?????
Hi All
I’m new here and I just bought a 1983 venture. It does have a few problems though.
The first one that I’m taking on is my head light. When the bike is running the bulb is very dim. High beam or low beam doesn't seem to change anything. Measured voltage at the bulb 2.5 volts both high and low beams.
I was hearing two relays clicking while messing with the high\low switch. One was gold in color with only the red wire with white stripe being hot under the low beam condition. Nothing was hot under high beams.
http://i133.photobucket.com/albums/q76/ChrisBonner/xvz1200%20pics/2014-03-10134458.jpg
One was black in color with 2 red wires with white stripes but only one was hot under the low beam condition. Nothing was hot under high beam.
http://i133.photobucket.com/albums/q76/ChrisBonner/xvz1200%20pics/2014-03-10134511.jpg
So I started to walk down the trouble shooting chart and got to step 6.
http://i133.photobucket.com/albums/q76/ChrisBonner/xvz1200%20pics/troubleshooting.jpg
That is assuming t this is the reserve lighting unit?
http://i133.photobucket.com/albums/q76/ChrisBonner/xvz1200%20pics/reservelightingunitcallout.jpg
So I get to “Check for voltage on (Y) and (G) wire from the dimmer switch to the computer monitor”
http://i133.photobucket.com/albums/q76/ChrisBonner/xvz1200%20pics/Dimmerswitchwires.jpg
On the yellow I get 3.76 volts
There are 2 green wires with no voltage on either of them. Anybody seen this or have an idea where to start.
Thanks
Welcome aboard and we hope you join. It will be the best $12 you will ever spend on your bike.
A dim headlight is a typical symptom of your CMS having a cold solder joint. It does concern me that both your high and low beam are giving you the same reading, which could be the start button, but this will give you a place to start.
RandyA
http://www.venturerider.org/forum/showthread.php?t=33328
Thanks everybody.
So I pulled the computer and it looked really good. I will solder the pins tomorrow and see what happens.
http://i133.photobucket.com/albums/q76/ChrisBonner/xvz1200%20pics/2014-03-11192102.jpg
http://i133.photobucket.com/albums/q76/ChrisBonner/xvz1200%20pics/2014-03-11192110.jpg
http://i133.photobucket.com/albums/q76/ChrisBonner/xvz1200%20pics/2014-03-11192119.jpg
  • 5 weeks later...
Ok the board is soldered.... but now when i hit the start button the headlight goes out but the bike doesn't crank over.... Is it possible I messed the broad up, affecting the starting circuit. On a good note the headlight has about 9 volts now at the bulb and the high low seems to be working as well. The computer seems to be working better. Just wont turn over now. :confused24:
Thanks Chris
The headlight going out when you hit the starter button is a good thing, it is supposed to do that.
As far as not cranking, check to be sure you did not bump off the red Kill switch on the top of the right handlebar. You would not be the first to have done that.
No, CMS shouldn't affect cranking, however just a guess.....since fixing CMS and you now show 9 V at headlight with key on....it should be close to battery voltage...might test your battery voltage....it might be only ~ 9 V there too. Doubt it will crank at that low of voltage.
If battery is normal ~12.6 V...possibly when pulling dash out the starting circuit cutoff relay was disturbed....on an 83 should have 4 wires...2 Red/White, 1 Black/yellow, 1 Skyblue. It'll be up there with all the other relays above headlight.
http://img.tapatalk.com/d/14/04/14/3adune2a.jpg
also tested the large red wire that goes up towards the kill switch start button and I'm getting 11.6 volts at the wires to the start button
Sent from my SCH-R910 using Tapatalk 2
