noworriespete Posted February 29, 2008 Posted February 29, 2008 I am getting a 84 venture that needs some cosmetic help. It *was* red, before getting baked in the sun, then the saddlebags were replaced with 1986 purple saddle bags. I would like to simply get some black plastic paint, a glossy finish of some sort, and paint it. Ive heard it will work, I have heard it wont work, or it'll chip, or flake off. The plastic is pretty old and brittle. What has worked in the past? Im working on a pretty small budget, so I know I cant get it back to the shiney "new" look. Also, wheres a good place to find a replacement seat? Thanks, Pete
lonestarmedic Posted February 29, 2008 Posted February 29, 2008 Sanding, prepping, cleaning and using a good primer-sealer are the keys to a paint job. You can get acceptable results with a rattle can. Use a handle and light coats. Overlap and don't get in a hurry. Or, remove the plastics, do all the prep work and then find a part time painter to shoot the color coat. JB
bongobobny Posted March 1, 2008 Posted March 1, 2008 As far as the seat, and other parts, ebay is the primary place to try. You may also check the clasifieds here as there are a few 1st gens being torn down right now...
Guest Shaggy Dog Posted March 1, 2008 Posted March 1, 2008 If you want it to look good with out putting a lot into the prep work stay away from Black. It's the hardest color to make look good. Every crack ,scratch, dent, wave or imperfection will show worse with black. A good paint store can match the color that on you have on your bike now with a scanner. You might try a clear touch up on the old paint an just paint the saddlebags with the store mixed rattle can.For just a few bucks you can test a small spot on the bike to see if the clear will help.But be sure to use automotive grade paint. Also always test a small spot to make sure it won't lift the old paint. PS I would prime the purple saddlebags before trying to cover with an other color. Just my Two cents, maybe a little more:080402gudl_prv:
