I have started one of 2 projects this one is going along easy so far. I turned a ring to replace the 4 1/2" lens in the driving light. I purchased a piece of aluminum tubing 4 1/2 OD X 3 1/2 ID. I cut a piece off about 1/2" thick turned and shaped in a lathe next used a piece of 1/4 thick rubber to use as a pressure fit between the light (3") and the hole in the ring.
  Bubber said:
I would like to see other pictures of it. just cuss I'm nosey and I like to see what everyone is up to.
And it looks kooooool too.
:missingtooth:
:sign yeah that::sign yeah that::322:
I'll pull it apart tonight and post a picture of the parts and what mods have been done to everything. I haven't pressed it together yet because I want to paint the ring I made to match the bike. The best part is once the ring adapter is made it's really up to you what light to put in it. Oh and Bob one guess what the second project is because I am tired of waiting on the person who said "Sure no problem I can do that for you".
Ok here are some photos of the parts used..... the 4th one shows how far the projector light sticks out but it has about another 1/8th of an inch to go.... Oh yea you can still use the lens shades also.
