Whistler Posted October 13, 2013 Share #1 Posted October 13, 2013 Had a problem this weekend lost everything the right turn signal went out then the neutral light and then the left turn signal and the next morn no brake lights after breakfast the speedometer the mileage gage nothing left . Had it tuned in July and I think they pinched a wire and finally wore through and ground out some where under the gas tank . any one have this happen before. Ron Link to comment Share on other sites More sharing options...
Prairiehammer Posted October 13, 2013 Share #2 Posted October 13, 2013 Any fuses blown? Link to comment Share on other sites More sharing options...
Whistler Posted October 13, 2013 Author Share #3 Posted October 13, 2013 No checked all fusses and still good . This all was in 2 days when I stop some where and get back on the bike there would be something else out..Ron Link to comment Share on other sites More sharing options...
PGunn Posted October 14, 2013 Share #4 Posted October 14, 2013 Check the wireing harness and see if it is rubbing on the steering neck some guys have had this happen and found wires worn through from the rubbing. Link to comment Share on other sites More sharing options...
GeorgeS Posted October 14, 2013 Share #5 Posted October 14, 2013 Possibly an connector has pulled loose. If any wires worn thru, there should be at least one blown fuse !! Are you sure you checked them all ?? Link to comment Share on other sites More sharing options...
MikeWa Posted October 14, 2013 Share #6 Posted October 14, 2013 Ground out will not usually cause this kind of problem. Check your charging system for over charging. Mike Link to comment Share on other sites More sharing options...
Whistler Posted October 19, 2013 Author Share #7 Posted October 19, 2013 Had it taken in to worked on and they said a fuse and the light and everything works good. If it was just a fuse it should go all at one time instead of over 2 days Ron Link to comment Share on other sites More sharing options...
spear Posted October 19, 2013 Share #8 Posted October 19, 2013 Time to trade up? Link to comment Share on other sites More sharing options...
Whistler Posted October 19, 2013 Author Share #9 Posted October 19, 2013 I would in a hear beat the wife what's to trike it out so she can drive it then I'd go get another ride ron:whistling: Link to comment Share on other sites More sharing options...
