Pressure68 Posted October 2, 2013 Posted October 2, 2013 So I have no headlight, checked the fuse all is good. Checked the bulb all is good but still have no headlight (highbeam or low beam). All the other lights are working except the head light grrrrrr . Could it be switch in (high/low) on the bar or is there a relay specifically for the headlight I'm missing ?
Trader Posted October 2, 2013 Posted October 2, 2013 check to be sure your starter button it totally disengaged. Might need cleaning. There is a thread on that in the tech section.
Evan Posted October 2, 2013 Posted October 2, 2013 check to be sure your starter button it totally disengaged. Might need cleaning. There is a thread on that in the tech section. Yes, this was my problem and I understand it is fairly common. I was surprised at the green crud that had accumulated when the switch was opened, and the thread gives an excellent step by step procedure for doing that.
Venturous Randy Posted October 2, 2013 Posted October 2, 2013 It helps to note what bike you are talking about as not everyone will take the time to look at your profile. You can also note it where your name is. We hope you join and it will be the best $12 you will ever spend on your bike. RandyA
KIC Posted October 3, 2013 Posted October 3, 2013 It helps to note what bike you are talking about as not everyone will take the time to look at your profile. You can also note it where your name is. We hope you join and it will be the best $12 you will ever spend on your bike. RandyA yea..what he said...also I had the same problem and it was my starter switch too.
Pressure68 Posted October 3, 2013 Author Posted October 3, 2013 Whoops sorry guys forgot to mention what bike LOL. Like Kevin said it's an 86' Standard thats not in bad shape but has gremlins for sure. With all the help here should be easy to get her back to the way she should be My bad, thanks for the tips and your right it will be the best $12 i've ever spent on my bike Kevin thats awesome your on here too I'll try the starter switch thing and keep ya posted
Pressure68 Posted October 3, 2013 Author Posted October 3, 2013 Thanks guys! problem solved, was the starter switch. Up and shining again
kevin-vic-b.c. Posted October 3, 2013 Posted October 3, 2013 Thanks guys! problem solved, was the starter switch. Up and shining again
Trader Posted October 4, 2013 Posted October 4, 2013 Thanks guys! problem solved, was the starter switch. Up and shining again Hey wadda ya know! I got one right!
