rbig1 Posted September 13, 2013 Posted September 13, 2013 well there was some one that didnt make it home from freebirds maint day. he compiled a list of stuff to test. cant remember for the life of me his name. should have subscribed to thread but that is another story. was up by fulton ill pulled up to stop. bike would not rev and tac was all over. rolled off to shoulder bike woke up. we made it back over to iowa. bike would miss every once in a while but made it home. took cover off and looked at fuse and wiring. but thought i would print out his flow chart of sorts so i dont keep testing same thing.
rbig1 Posted September 13, 2013 Author Posted September 13, 2013 have a new tci on bike. from ign tec. all connectors were cleaned at that area. dash plugs were also cleaned. replaced one coil and all wires to plugs ngk ends. replaced kick stand switch. cleaned switches on handle bars ie separated and sprayed with sandpaper used also. if i remember correct #2 coil controls tac pickup am i right. i have rode the bike over 3500 miles this year. carbs are rebuilt. fuel tank was cleaned took off bike. started to get radio noise like ign feedback. while on last voyage not bad just there figured that was the antenna.
Flyinfool Posted September 13, 2013 Posted September 13, 2013 That might have been me that you were thinking of. http://www.venturerider.org/forum/showthread.php?t=79093 http://www.venturerider.org/forum/showthread.php?t=79290 Do you still have the stock glass fuses? Did I ever mention I hate intermittent electrical problems. Good luck
rbig1 Posted September 14, 2013 Author Posted September 14, 2013 jep printed out a few ideas. still have stock fuses. had bike running and i touched each fuse headlamp and ign fuse taught me a new language. had the radio on when i played with wire static would come and go need to find my resistance. think headlamp is just the load. but ign fuse shouldent get that hot.
Flyinfool Posted September 14, 2013 Posted September 14, 2013 The clips in the stock fuse holders are junk, if the fuse is getting hot, it has a bad connection. Put in an AGM fuse block, it will cure many electrical evils.
rbig1 Posted September 14, 2013 Author Posted September 14, 2013 well started to throw fuse holder on ign wire. changed my mind went to boat shop bought a fuse block with built in ground lugs. then went to parts store bought 5 gang fuse cluster and gold terminals replaced all glass fuse assy. at the top of old fuse box was a lonely ground lug. added it to boat shop one. then added a ground wire to battery. put bike back together for test run. best it has ever ran. cant be-leave the difference... now to fasten down fuse holders. will have to add a relay for accy wires as stock wire small want air horn and garman,etc. have them on bike already just need to find a place for compressor. have trumpets:dancefool:any idea where to hide compressor.
