calperin Posted September 3, 2013 Posted September 3, 2013 I receive saturday the carb covers and the twinkles from AD Chrome. They are really nice, but after install the right side I realize that I found on the back of the cylinder heat sink a piece that I believe should belong to the carbs. I attached both pictures, the cover and twinkle and the piece that seems to be a jet or some injection limitation piece on the carbs... All that I had to do is replace the original screws from the carb cover to a larger screws with a spacer to hold the new cover. Is any way that this piece falls from behind the original screws? I didn't saw anything fall, but still I don't believe that I have that piece loose for such long time. BTW, I run the bike, and I had no issues at all, so it doesn't seem that something is missing or the carbs are not working properly... Any thoughts? :confused07::depressed: [ATTACH]79758[/ATTACH] [ATTACH]79759[/ATTACH] [ATTACH]79760[/ATTACH]
calperin Posted September 3, 2013 Author Posted September 3, 2013 I don't think so. The screws are not so wide. May be the spacers... However the cap has a small hole like a jet one...
V7Goose Posted September 5, 2013 Posted September 5, 2013 That is just the stock anti-tamper cover fitted over the air mixture screw - one on each carb. Never have seen one fall off on its own before, and they are not particularly easy to reach with the carbs in place, but I suppose it is possible you hit it with something while under there. Nothing to worry about. Those covers are never replaced once popped off for fuel mixture work. If all four are off, then it probably has been laying there for years after someone adjusted the carbs long ago. Goose
calperin Posted September 5, 2013 Author Posted September 5, 2013 Ok, That makes me feel better. Last time we did carbs was last year when I purchased the bike. Had to be loose and some way it falls when I install the carb covers. Thanks, Carlos
Condor Posted September 5, 2013 Posted September 5, 2013 I don't think so. The screws are not so wide. May be the spacers... However the cap has a small hole like a jet one... Yep there are spacers behind the covers....
