Huggy Posted August 26, 2013 Posted August 26, 2013 Does the controller for the CLASS have an air line attached to it? I had it apart to clean up the plastics and noticed there is a plastic tube inside the CLASS box and there is a corresponding hole in the plastic case is there something I am missing here? All of the electrics were off of the bike when I got it so that's why I'm asking.
Condor Posted August 26, 2013 Posted August 26, 2013 Does the controller for the CLASS have an air line attached to it? I had it apart to clean up the plastics and noticed there is a plastic tube inside the CLASS box and there is a corresponding hole in the plastic case is there something I am missing here? All of the electrics were off of the bike when I got it so that's why I'm asking. I've never seen any sort of tube in any that I've opened up. Might be a McGuiver attempt by a PO to get rid of moisture...???
Huggy Posted August 26, 2013 Author Posted August 26, 2013 OK thanks for the info. You are probably right as this bike was never garage stored. The radio, cassette, CB unit all look like they have been very wet at sometime. But thanks to JohnT I have replacements for them. The CLASS looks in good shape. But I'm going to look for a replacement just in case its shot from to much moisture.
camos Posted August 26, 2013 Posted August 26, 2013 Does the controller for the CLASS have an air line attached to it? I had it apart to clean up the plastics and noticed there is a plastic tube inside the CLASS box and there is a corresponding hole in the plastic case is there something I am missing here? All of the electrics were off of the bike when I got it so that's why I'm asking. Possibly the tube is the overflow for the coolant bottle.
Huggy Posted August 26, 2013 Author Posted August 26, 2013 No, There's a short tube about the same diameter as the coolant over flow tube in side the CLASS case. And in the same corner there is a hole in the case and it looks like it belongs there. Does not look like someone added it.
rbig1 Posted August 27, 2013 Posted August 27, 2013 Mine had to tube also just drains off excess water there is a strip of rubber at bottom of screen leaks water . Just resolder the plug as in instrctions. Use eraser to clean joints then spray off when I soldered mine had to remove solder then get hot enough that it sizzled added new solder and it works. They are super slow settiing.
