Evan Posted August 17, 2013 Posted August 17, 2013 Suddenly without warning it died. Recently disconnected cable at wheel and greased inner cable, which looked good. Is there a good chance that the cable separated at upper attachment? What is best way to access this?
BOO Posted August 17, 2013 Posted August 17, 2013 (edited) Yep, had that happen before. If I remember correctly you can barely get your hand up in there and screw it back on. Have to take the head light out of course. BOO The cable actually comes out from the bottom end so you could take it loose there to see if it has broken. Good Luck, BOO Edited August 17, 2013 by BOO More Thoughts
Marcarl Posted August 17, 2013 Posted August 17, 2013 Did it scream or screech before it died? You may have lost the inner cable if the bottom end came loose. I have a spare if you needs it.
Evan Posted August 17, 2013 Author Posted August 17, 2013 Thanks guys. Problem solved. I went for a quick look and figured out how to access and reconnect the cable behind the headlight. Glad I don't have bigger hands.
