SpencerPJ Posted August 3, 2013 Posted August 3, 2013 1983 Venture I have the dreaded drip by kickstand, losing a bit out of clutch reservoir daily, and getting worse so I plan to replace the clutch slave. Not super savy, I thought I'd just replace rather than try to rebuild. I have a couple P/N questions: The Push Lever Comp: 1FK-16381-11-00, does that come complete, or do I also need to buy the Seal Kit (26H-W0098-00-00)? OR anything else? Is the Middle gear cover gasket p/n = 3JP-15451-01-00 ? I've got a couple conflicting p/n's and I hate to order parts wrong. Should I order the copper washer 90430-06014-00 ? Any feedback or advise would be great, Thanks I've found a couple detailed threads on replacing, looks do-able. Spencer
mbrood Posted August 3, 2013 Posted August 3, 2013 The fiche shows 1FK-16381-11-00 as the entire assembly, rome assembly - replace assembly - bleed. The rear side cover gasket should be 3JP-15461-01-00. Any copper (crush) washer is designed to be slightly formable by compression. Time hardens the copper. Put it over a gentle flame until it glows cherry red and then set aside to air cool and voila... it's annealed and once again ductile (formable). When it's all squished out to a this area under the bolt and only thick outside the bolt head, THEN you need a new copper washer and there's certainly no need for it to be a "Yamaha" part.
IH Truck Guy Posted August 3, 2013 Posted August 3, 2013 Get a hold of Earl, Skydoc17... he has all the Right parts at a fair price... And is there to answer any ??? along the way.
cabreco Posted August 3, 2013 Posted August 3, 2013 1983 Venture I have the dreaded drip by kickstand, losing a bit out of clutch reservoir daily, and getting worse so I plan to replace the clutch slave. Not super savy, I thought I'd just replace rather than try to rebuild. I have a couple P/N questions: 1st here is my write up so you know what you're getting into. http://www.venturerider.org/forum/showthread.php?t=66302 The Push Lever Comp: 1FK-16381-11-00, does that come complete, or do I also need to buy the Seal Kit (26H-W0098-00-00)? OR anything else? The slave cyl comes with the seals installed (it better for $70) http://www.boats.net/parts/detail/yamaha/Y-1FK-16381-11-00.html Is the Middle gear cover gasket p/n = 3JP-15451-01-00 ? I've got a couple conflicting p/n's and I hate to order parts wrong. I bought #JP-15461-01-00 for my 84. If you take your time removing it you may get lucky like I did & not need to replace it. http://www.boats.net/parts/detail/yamaha/motorcycle/Y-3JP-15461-01-00.html Should I order the copper washer 90430-06014-00 ? When I did mine I did not buy them & did not need to. Any feedback or advise would be great, Thanks I've found a couple detailed threads on replacing, looks do-able. Spencer Good Luck & "Happy Cursing"!
