Alex Posted February 10, 2008 Share #1 Posted February 10, 2008 Can someone offer advice? I have an 06 RSV. Yesterday I washed her, and when I fired the engine, it was apparent that I had a cylinder down. Turns out to be the right rear. Pulled the plug wire and plug. Plug was wet. Took another wire off and put the plug to ground. It fired hot. Exchanged the plugs and the problem is still with the right rear cylinder. I tested the plug wire cap to ground and got a momentary resistance of around 14K...tried a working wire and got the same result. I haven't pulled the coil yet because it is like 18 degrees outside! I have a hair dryer blowing warm air on the coil in case it got wet, but so far no change. Thanks for any help you guys might have. :confused24::confused24::confused24::confused24::confused24::confused24: Link to comment Share on other sites More sharing options...
Redneck Posted February 11, 2008 Share #2 Posted February 11, 2008 Probably just wet but I have seen the coils go bad. let it dry out if it doesn't clear up take it to the dealer and they will warranty it. Link to comment Share on other sites More sharing options...
