rjmalizia Posted November 17, 2006 Posted November 17, 2006 Riddle me this Batman... As far as I have been able to determine, my 1997 RSTD can muster approximately 75 horses, yet the 1200cc Vmax of that era had 100+/- ponies. What gives? Where are they hiding, and are there ways (inexpensive ways) of corralling em up. As always, thanks for your opinions.
Tartan Terror Posted November 17, 2006 Posted November 17, 2006 Check out this thread. Pegscraper and Wpredock are the ones to pay attentions to in here on this thread. http://www.venturerider.org/forum/showthread.php?t=2803&highlight=vmax+cams
Yammer Dan Posted November 17, 2006 Posted November 17, 2006 LARGE rubber band and hook it to the next 1st Gen that goes by!!
Toolman Posted November 17, 2006 Posted November 17, 2006 the Max has higher compression pistons and a V-boost and a diffrent transmission and rearend. it is geared for the strip
GeorgeS Posted November 17, 2006 Posted November 17, 2006 Just buy a used V Max, cheaper then converting. Lot less work and headaches
pegscraper Posted November 17, 2006 Posted November 17, 2006 Camshaft/valve spring and carb swaps aren't all that difficult depending on how handy you are, and make a huge difference in the early Royal Stars. I'm making 90 rear wheel/106 crank hp in my '96. That 75 hp figure you mention must be crank. After cams and carbs the mods get a little more difficult.
