Black wing Posted March 2, 2013 Share #1 Posted March 2, 2013 i stupidly lost a piece of my compressor while cleaning it and of course its the only part discontinued everywhere http://www.partzilla.com/parts/search/Yamaha/Motorcycle/1986/VENTURE%20ROYALE%20-%20XVZ1300DS/LEVELING%20UNIT/parts.html if any one has a broken compressor laying around i need part 12 (its the double male end brass piece that screw into the compressor itself) Link to comment Share on other sites More sharing options...
bongobobny Posted March 2, 2013 Share #2 Posted March 2, 2013 That should be a standard metric coupler that you should be able to find online... Link to comment Share on other sites More sharing options...
mralex714 Posted March 2, 2013 Share #3 Posted March 2, 2013 That should be a standard metric coupler that you should be able to find online... Or maybe at Lowes Link to comment Share on other sites More sharing options...
Black wing Posted March 2, 2013 Author Share #4 Posted March 2, 2013 hmm i'll have to take a run to few shops tomorrow, but we havent got a lowes, wallmart has none, canadian tire has none, so i will try home hardware tomorrow Link to comment Share on other sites More sharing options...
Marcarl Posted March 3, 2013 Share #5 Posted March 3, 2013 hmm i'll have to take a run to few shops tomorrow, but we havent got a lowes, wallmart has none, canadian tire has none, so i will try home hardware tomorrow Let me know if you can find it, if not, I'll send you one. Link to comment Share on other sites More sharing options...
bongobobny Posted March 3, 2013 Share #6 Posted March 3, 2013 Carl to the rescue!! Link to comment Share on other sites More sharing options...
Daitan Posted March 3, 2013 Share #7 Posted March 3, 2013 Similar subject about the air compressor, my front holds air, but the rear will need to be aired up on a daily basis. any thoughts??? Link to comment Share on other sites More sharing options...
jasonm. Posted March 3, 2013 Share #8 Posted March 3, 2013 that's an air joint(hose) coupler. forget Lowes or 99% of the big box stores. Try a true value hardware store. It's likely metric..thus it's not easy to find. I have similar parts off "air" sprung forks. We would need to know the thread size/type. You can figure this out using bolts that thread in. Link to comment Share on other sites More sharing options...
Black wing Posted March 3, 2013 Author Share #9 Posted March 3, 2013 (edited) so i just took a closer look at my compressor and just noticed my hoses dont match the diagram.. i have a hose with one male and one female end and one hose with two males. does my bike have the wrong assembly for the year? oh and daitan i would find out it the rear shock was leaking or your valves are not closing right, i that issue with mine ecept it was the front loosing pressure and i turned out my dessicant was so saturated i had water in the valves and was mucking up the system. so first get some de-greaser clean the hoses and rear shock till you could eat off them then try spraying it with soap and water like your looking for a tire leak if nothing from any connections or hoses i would try and block off the rear hose output with a bolt and an oring and leave it overnight and see if it reads in the morning. if it still has pressure in the morning i would say bad shock and if its empty i would say you've got a valve not closing right Edited March 3, 2013 by Black wing Link to comment Share on other sites More sharing options...
Marcarl Posted March 3, 2013 Share #10 Posted March 3, 2013 Similar subject about the air compressor, my front holds air, but the rear will need to be aired up on a daily basis. any thoughts??? You got a leak! Use soapy water to find it then fix it. Link to comment Share on other sites More sharing options...
Marcarl Posted March 3, 2013 Share #11 Posted March 3, 2013 so i just took a closer look at my compressor and just noticed my hoses dont match the diagram.. i have a hose with one male and one female end and one hose with two males. does my bike have the wrong assembly for the year? At this point a picture might be handy. Link to comment Share on other sites More sharing options...
Black wing Posted March 6, 2013 Author Share #12 Posted March 6, 2013 sorry for the wait on the pictures but heres what it looks like Link to comment Share on other sites More sharing options...
Marcarl Posted March 6, 2013 Share #13 Posted March 6, 2013 sorry for the wait on the pictures but heres what it looks like Is this the piece you need? Link to comment Share on other sites More sharing options...
Black wing Posted March 6, 2013 Author Share #14 Posted March 6, 2013 thats the piece thats is suposed to go there but my hose has a different end on it, i wonder if mebey i done need it and im just losing my mind that it was there in the first place Link to comment Share on other sites More sharing options...
Guest Robair 1946 Posted March 7, 2013 Share #15 Posted March 7, 2013 I have lots of that sort of stuff around. If you will send me your address, I will just send you the piece you need. I am located in Calgary Alberta Canada. Rob Link to comment Share on other sites More sharing options...
