Barry1951 Posted February 18, 2013 Posted February 18, 2013 OK, , , The Fat Boy is coming to the well of knowledge to ask for information, , , I bought a set of bag guards for my 06 RSTD, , , ,bought them frpm Calvacade on Ebay. They are supposed to be for an 06 RSTD, , , I tried to put them on today, , , not successful, , , , , I did not get any instruction but the look straightforward. I took the left saddle bag off and put the rail bolt and holder in the crash bars,, took the allen bolt (one above the trailer hitch mount). When I bolted the rear mount in, the front rail would not come close to fitting into the mounting bracket on the crash bar. I pushed and pulled and finally got it to reach but then it rubbed the side of the bag. No way that was correct. Any suggestions? ? ? ? ? ?
slowrollwv Posted February 18, 2013 Posted February 18, 2013 Most people set the front bolt in place then lower the bottom rail to run along the bottom of the saddle bag and drill a new hole in the fender rail. You might want to check the width on the back part of the rail sometimes they get bent in shipping.
Globewalker Posted February 19, 2013 Posted February 19, 2013 yea connect front part first and likely need to drill new hole like depicted in this nice write up someone did http://www.venturerider.org/forum/showthread.php?t=6365 I bought some (non-OEM) ones off of ebay and had to do similar reshaping and drill new hole to get them to fit right but look good once done good luck
