jimmyenglish Posted August 14, 2012 Posted August 14, 2012 Just put my 86' back together and one of my favorite features, the trunk light seems to have croaked. Oddly, the hazards don't work. Fuses fine. Are they related? Thanks!
Prairiehammer Posted August 14, 2012 Posted August 14, 2012 I believe the trunk light is fused from the HAZARD fuse. 15amp. Double check that the fuse holder clips are making good contact with the fuse itself. VERY common problem with our first generation fuse blocks is bad fuse clips. Sooner or later you will have to replace the OEM fuse block. Most convert to the ATC type fuse blocks. Skydoc_17 has a kit for that.
