timk Posted January 18, 2008 #1 Posted January 18, 2008 This from a FJR site, the Royal Star Venture was included. Key blanks: Ilco ym63 Tayler X 248 Curtis yn 63 Silca yh35r I HAVEN'T TRIED THESE, but if you need a extra, you can give one of these a try and report back
wkboard Posted January 18, 2008 #2 Posted January 18, 2008 Thanks TIMK! Good info to put in the file for that day when I need it. Thanks!!
awsmsrv Posted January 18, 2008 #3 Posted January 18, 2008 Starparts.org has the key blanks, as well, & some very nice ignition key covers. I have the original star badge. If you didn't know otherwise, you'd think it's just an ornament rather than the key in the ignition. Check it out.
Bummer Posted January 18, 2008 #4 Posted January 18, 2008 timk said: This from a FJR site, the Royal Star Venture was included. Key blanks: Ilco ym63 Tayler X 248 Curtis yn 63 Silca yh35r I HAVEN'T TRIED THESE, but if you need a extra, you can give one of these a try and report backThe Curtis key number is YM 63. I have several. They work fine, though they aren't as pretty as the originals.
MrRadi8 Posted January 22, 2008 #5 Posted January 22, 2008 My local ACE Hardware store carried blanks for my scoot. Which made me a whole lot happier than only having the one set, the non-ignition one bent!
kantornado Posted January 24, 2008 #6 Posted January 24, 2008 I have these 2 types, Tayler X 248, Curtis yn 63 and they work fine.........................................................Ron
Uturn Posted January 24, 2008 #7 Posted January 24, 2008 I had to put another switch on my 99 RSV. This left me with having to carry two keys (ignition, gas,bags/trunk). Several years ago, I had two Fords and the keys were like the Venture - double sided with the same cut on either side. Back then, I had the Locksmith cut one key on one side and cut the other key on the opposite side. (Hope this makes sense). I did the same thing with the Venture keys. For the switch, You need to ensure you put the key in right side up. I took my Dremel and cut a notch in the top. When I open the gas cap or saddle bags/trunk, I use the un-notched side up. Oh, the blank I use is a ilco X248 YM63. Just a plain silver key. Remember to do this, the (combo) keys have to be manually cut. Hope this helps. MIKE aka Uturn
