Uturn Posted March 15, 2012 Share #1 Posted March 15, 2012 About a year or so ago, I was on a trip and when I started to down shift, my shift lever was dangling from the rod and laying on the footboard. The allen head bolt that mounts it to the bike had come out, and gone. I managed to use a cable tie to connect it back to the bike and able to get to the nearest AutoZone to buy a metric bolt that would fit. I hadn't thought anymore about that since it happened until today. My buddy came down around lunch time and said "you'll never believe what happened to me on the way to work this morning!" Yep, his shifter allen head bolt vibrated out. Lucky for him, it was laying on the floorboard and he put his foot on it until he could stop and put it back in. Suggest every one take a minute and check that bolt and maybe a little lock tite wouldn't hurt. MIKE aka Uturn Link to comment Share on other sites More sharing options...
Venturous Randy Posted March 15, 2012 Share #2 Posted March 15, 2012 Good note Mike To go along with this, I suggest, especially to 1st genners, to check the bolt holding the side stand and make sure there is not too much play. This is the number one cause of side stand problems and trying to make it home without being able to use your side stand can be a PIA. RandyA Link to comment Share on other sites More sharing options...
09RSTD Posted March 15, 2012 Share #3 Posted March 15, 2012 Suggestion. Not only should you check this bolt for tightness, while your at it why don't you remove it and put a nice light coat of LockTite in/on the threads. Then worry no more! Link to comment Share on other sites More sharing options...
bongobobny Posted March 15, 2012 Share #4 Posted March 15, 2012 Yup! Happened to several of us! The screws that hold the "battery" covers on the side use the same bolt and in an emergency situation it will get you home! Use loctite and you will never have to worry about it again... Link to comment Share on other sites More sharing options...
