BoomerCPO Posted January 10, 2012 Posted January 10, 2012 Can the 12V ACC plug (located on the left inside of the front fairing of my 06 Venture) handle powering up my GPS and a Roady2 satellite radio? Boomer....who sez thanks in advance for any responses.
BuddyRich Posted January 10, 2012 Posted January 10, 2012 More than likely. I think its a 5 amp fuse, but both of those devices are low amp type devices so you should be good to go
BoomerCPO Posted January 10, 2012 Author Posted January 10, 2012 More than likely. I think its a 5 amp fuse, but both of those devices are low amp type devices so you should be good to go Thanks Buddy!! I didn't want to risk pooching up anything electrical on the scoot.... Boomer....who knows enuff bout electricity to stay the heck away frum it....
midnightventure Posted January 11, 2012 Posted January 11, 2012 I run my GPS off it all the time. Don't try to run an air compressor from it though.
BradT Posted January 11, 2012 Posted January 11, 2012 I run my GPS off it all the time. Don't try to run an air compressor from it though. Did that once before I read the fuse size. ! I didn't want to risk pooching up anything electrical on the scoot Won't hurt the bike but if you blow the fuse you will have to take ;ower right fairing off to replace the fuse. Brad
