muaymendez1 Posted June 4, 2011 Share #1 Posted June 4, 2011 http://i257.photobucket.com/albums/hh221/muaymendez/IMAG0235.jpg Will the angle of the bars cause problems with the feed of fluid for the brake and the clutch?? http://i257.photobucket.com/albums/hh221/muaymendez/IMAG0236.jpg Link to comment Share on other sites More sharing options...
TearlessTom Posted June 5, 2011 Share #2 Posted June 5, 2011 I don't see any reason that it would. Your outlet is still way below the fluid line and the system is pressurized so as long as you are not vertical with the outlet at the top there should not be any issues that I can foresee. Link to comment Share on other sites More sharing options...
Darren Posted June 5, 2011 Share #3 Posted June 5, 2011 My angle is just as low as yours (maybe lower) and have no issues at all. Except checking fluid levels with caps off!! thankfully i had rags on the tank!! Link to comment Share on other sites More sharing options...
muaymendez1 Posted June 6, 2011 Author Share #4 Posted June 6, 2011 My angle is just as low as yours (maybe lower) and have no issues at all. Except checking fluid levels with caps off!! thankfully i had rags on the tank!! :clap2: YES MAN !!!! that is too funny. Thanks for the responses. I will be getting some risers and then will be able to move the bars a bit. These are road glide bars and they feel better but A lil too forward. Link to comment Share on other sites More sharing options...
