Saddle_Bag Posted January 12, 2011 Share #1 Posted January 12, 2011 With all the foul weather, the old girl is taking a cold weather nap. Started her today and noticed that oil is coming from the shifter stem. I assume there is a bushing of some type???? I have never had a drip from there before. How do I stop the drip??? joe:starz: Link to comment Share on other sites More sharing options...
Snaggletooth Posted January 12, 2011 Share #2 Posted January 12, 2011 Check around the back of the stator cover where the wires come through from the stator. It's a rubber plug in the case and the wires run through it. The OEM wires can wick oil out and cause a wet spot. Mine did that during the cold months until I replaced the stator and gooped the daylights out of the inside and out of the plug. You would need to pull the rear, secondary cover to get a good look at it. Mike Link to comment Share on other sites More sharing options...
MiCarl Posted January 12, 2011 Share #3 Posted January 12, 2011 Pull the rubber plug off the clutch slave cylinder and jam a tissue down in by the wires. Run it for a few minutes and pull the tissue. If it's got oil on it you found your leak. Link to comment Share on other sites More sharing options...
Snaggletooth Posted January 12, 2011 Share #4 Posted January 12, 2011 Oh sure! ....NOW I find out there is an easy way to check that plug!! Link to comment Share on other sites More sharing options...
